Yes it will.
As far as I know, the oil pump in the picture should be exactly the same as what you will find in your 2F engine.
One thing on removing the Phillips head fasteners that retain the aluminum pick up and lower half of the oil pump:
I used a Snap-On #3 Phillips that has a 7/16” wrench hex on it by the handle, along with someone pushing down on the top and helping turn the fastener, as these were not going to simply come out. I also used a hammer and seated the screwdriver into the fasteners, and had to use a flat punch to try and repair/make flat again the Phillips head of one fastener in order to get them all removed. That is why I now have installed hex head fasteners when I reassembled the pump and pickup body.
If you do not own a quality screwdriver, you will want to purchase one, at the very least, a Craftsman Pro Series or something equivalent. Trying to remove these fasteners when the head is stripped would not be fun at all.
Good luck!
-Steve
