h55 noisy through shifter
Longmont, CO
i have an h55 in the gilfriends truck that is a bit noisy, you can hear whirring/gear noise through the shifter, especially when you press it against the side of the gates.it worst under load, silent when coasting, and present in 1st, 2nd, 3rd, and 5th. even though 4th is far quieter i can still hear it when i press on the tc and pto shifters.oil is fresh 80w-90. shifts fine, though when trying to push it into a gear the noise lets me hear the synchros working to spin things up or down.so what do you think that is, any bearing in particular? gears themselves? any way to quiet it down? - its not bad (gf doesnt notice and PO didnt mention it, tho its been there as long as i had it) but its burrowed into my brain and is irritating me....
This is not a fix but does help quiet it down, flush case and refill case plus two bottles of Lucas tranny additive .
Worn bearings cause this howling noise under load.
I had one so bad you could barely hear the person next to you in the cruiser when he spoke. Once rebuilt/rebearinged, it was oh so quiet....
Rob
my h55f is noisy at the shifter,i put lucas and its a bit better,its in a hzj 73 1991,220000 km.i plan to rebilt in the next year,its my dd
H55f
The H55 can be noisy at the shifter. The newer ones have an insulator built into the stick. You can tell the difference because the stick is quite fat half way down.
Recently fixed the sons H55. It was real noisy in all gears except 4th.
The problem was the rear counter shaft bearing. The bearing is a straight roller which uses the shaft as the inner race. The shaft gets worn and the hard surface wears off and all the gears get out of line except 4th which is direct. The fix is replace the bearings in the trans and the counter shaft.
There is an after market gear available for about $400+
However there is another way.
One of the weakness of the H55 is the non replaceable inner race of the rear countershaft bearing. All the other roller bearings which matter have replaceable races except that one.There are other needle roller bearing which use the shaft as the race but they don't carry much load, they only turn when the transmission is not in that particular gear, so the gear just floats on the shaft.
So make the race replaceable and reuse the counter shaft.
Turn the rear bearing race in a lathe, the material is relatively soft, carbide tooling has no trouble reducing the diameter. Find an inner race from a needle roller bearing that has the same outside diameter as the original shaft race. Then shrink fit the new race to the shaft and you have a new bearing surface for the new roller bearing to run on.
The sleeve is slightly shorter than the original race but the bearing surface is plenty wide enough for the width of the roller in the bearing. Used 0.0025 + shrink fit and heat the sleeve up a bit ( heating base on a coffee maker works well to heat the sleeve) and drop it and tap it home. You may have to polish the sleeve a little to get it to 40mm diameter.
This reduces the cost of the overhaul to cost of machining and the new sleeve ($30.00 for the sleeve?) Overhaul kit from Kurt $200? Plus the time to do it.
Hope this helps.
Thanks jb
couple more pictures
More machining and shaft pictures
Nice work. You want some more? I have three worn out F55fs and I'd love one good one. Let me know if you are interested in giving me a quote to rebuild one.
