Gifted an 80 (2 Viewers)
I would look at magnaflow they have bolt in cats for the later 80 series, but check the website they might have some for the earlier ones. Since it is a CA rig you have to get CA compliant cats, but with the tags still out of state you might get away with ordering Federal compliant cats and save you tons. The only way you can get the non California compliant ones is to have them shipped to family outside of CA and they forward them to you. IN NO WAY AM I TELLING YOU TO DO THIS.
I would never circumvent my progressive overlord governor. Shame, shame.
Thank you. I saw they sell tubing seal kits. Hopefully that will cover it.
The copper tubing used is standard 1/4" OD copper refrigeration tubing that you can buy at your local hardware store.
Make sure you ream the ends with a drill bit after cutting them off so you don't have restrictions. Also make sure to blow out the lines before you do final installation so there are no chips or debris in the lines.
You're the man! Thank you. Anywhere I can save some cash on this is awesome!
I just watched a video on the ARB locker airline. This is going to be fun. Here’s to learning how to do new stuff (and hopefully right the first time.)
I recommend using a bender to shape the line do you don't crease it when bending. All bends should be as long and sweeping as you have room for.
Take a look on this site for pics of other ARB installations to see the proper routing of the line.
Forsure man. I appreciate the tips. I’m new. Right now front lockers are not a priority. But it’s on the list.
I need to get it running good. Then I’ll deal with front lockers. I’ve got quite a list going. I talked with the cruiser outfitters today. I’m not sure if I have a 2.5, or 3.5 lift. I’m right around 24” from center hub to bottom of wheel well. Is that a 3.5” lift?
I’m back tonight for my 5th pressure wash. I bought a smaller wand to get into tight spots. I’m about to degrease, to prep for rust inhibitor tomorrow.
these look aftermarket to correct geometry, is that a fair assessment?
Yeah, as said they help say bars work properly with your lift.
Can't see any caster correction in those pics. Take a pic of where the front radius arm connects to the chassis.
Hard to be sure, but the angle of the radius arm looks like there may be drop boxes to lower the connection point at the chassis and fix steering geometry
If you're right that is 3.5" of lift, if there's no caster correction been done you'll likely have negative caster and funky steering.
Also, I don't think your front driveshaft is a factory part. At least, the uni joints are not
