Builds Frog's FJ159
Here is mock up on spacer
That turned out really nice! I would be looking into a way to tie a support back to the block pretty seriously. That's putting a bunch of stress on your new tunnel as well as the manifold. clearly it's ok static, but driving down the road (not to mention heat cycles) will be a different story.
Will be doing a support brace, easy to do off off of the engine ground bolt
I see you have the same welding shoes/bottle opener that I use.
Nice....:cheers:
I hope you had the safety squints engaged under those glasses.
Check out the trace from that spark!
In under the bottom of the lens, hits the cheek, out past the top of the frame. :eek:
Eyes closed, just giving metal a quick fright before welding
That's a gorgeous aircraft.
