Builds Frog's 40
Where did you get your aircraft profile cutouts? Those are cool. I'd love to see them for the airframes I've worked.
Oh, and the 40 work is coming along nicely!
I have a buddy that makes them, I can send u his info. It's db Marvel's, he does some cool stuff
Engine is in, have to pull it, finish welding and paint frame. Any recommendations for a good paint for the frame?
After a little cussing, smashing knuckles a couple of times it's in. Always that one last bolt that fights you. Next step is to align axles with transfer case, order driveshafts, and start the plumbing and electrical. Should be easy they said...
Transfer case ended up 22.5 inches off the ground, and frame rails are just under 24
Trying to decide if I need a CV driveshaft for the rear. 32" from flange to flange, transfer case is 8.5 inches higher. Let me know what you guys think.
I think 32" is longer than a stock 40 shaft. As long as your flanges are parallel, a normal u-joint should be fine.
I'm leaning towards normal shaft for the rear, I will rotate the pinion down to make them parallel. Perches are not welded yet. Anyone else think I'm good with normal in the rear?
Well after talking with Jesse at high angle drive lines the angles call for a CV driveshaft at both sides. Ordered up and should receive them in a week or two
What clutch setup/slave and flywheel did you use with the AA bellhousing?
Center force 11 inch disk and pressure plate, stock slave, AA expensive flywheel for ls motors and their bellhousing
Just found this thread.... tires look awesome.
