Build Frog's 40
Front axle, spring mounts, and old engine mounts mostly out. A little more grinding and will be rdy to start installing front suspension
Well that was lots of fun, lots of grinding to get old engine mounts off. Some people should not be allowed to weld. I can't believe they actually held the motor in there.
I feel your pain. I had to cut so much off my frame and thought the same thing. Then I welded more to it. What I did will not be as easy to remove if at all. If I ever sell it the new owner is going to have to like what I did.
I hate all that grinding cutting that goes with cutting old brackets off. Nice work yours looks good.
Front mock up, the Tahoe springs are so long I am having a hard time pushing front axle forward. I was hoping to get it forward 3", but then the springs will stick out way to far up front. Going to settle for 1" forward and move the perches to get another inch.
Thoughts? By the way mocking this up by yourself sucks, it's definitely a lot easier with another person to get measurements
Not sure how a perch like this would work on the front axle, but it could give you the 3 inches you’re after...
Cool build. I'm looking at the Liquid Iron sliders and Tahoe springs for one of my builds. Curious on how you determined placement of the perches and sliders. Did you tack them in and see where they sat on it's own weight?
They are super easy to determine. Just measure the length of the spring from eye to eye along the arch of the spring and that will be your maximum distance. Add a little to that for safety. Axle will normally lined up around 27-28 inches from the fixed perch point
Nice work! I have been eyeing those sliders for a build for a long time. I want to try them in the back like you have them set up, might be copying your setup here someday! Cant wait to see how this one comes out!
