Michael B
Also track which push rod and lifter came from which hole. It is important that they all go back in their original place.
Will it be straightforward to re-seal the plate with the gear still on the crank? Now that I look closer it seems it's pretty doable.You don’t need to remove the crank gear; the plate has a hole in it for the gear to pass through.
You ABSOLUTELY DO need to turn the crank/ flywheel to top dead center so the alignment marks on the crank and cam synch BEFORE YOU PULL THE CAM.
I'll look back and see if I can see what the number for them was, but I'm pretty sure they were oem replacement for those flat head screws.In four decades of wrenching on cruisers I have never seen those screws before Aaron.
I learned something new today!![]()
Yes you beat me to it.@airon23 @65swb45 @Honger
Here you go, post #97:
How not to build the 2F
Yes, the CR goes up directly the same % as the increase in displacement. So if the displacement is increased 10% on a Model T ford, the CR would go from 4.0 to 4.4 (phffft). Increase displacement 10% on a modern engine, the CR goes from 9.5 to 10.5.forum.ih8mud.com
So helpful!! Thanks a bunch. Replacements ordered!Also while you're in there be ready to remove these which could be a real PITA. Be ready to replace with the factory replacement hex bolts instead to avoid this next time.
They might get boogered up like this
A couple more pics for your reference
I’d forgotten this thread… epic read.@airon23 @65swb45 @Honger
I can't now recall, but I want to say I used just a very light layer of the sealant like @Michael B mentioned.Hey @airon23 or @65swb45 or @Michael B or anyone else...
Do you do the OEM gasket sealant on both sides of the gasket for the end plate? Also for the timing cover cork gasket, right?
I read @Poser's thread in the FAQ for the side cover and oil pan gaskets, so know where to use the sealant there.
Would love more thoughts/input on best practices for preventing future leaks.
I usually apply sealant to both sides of a gasket. But I have never worked in that particular area of a 2F before.
So I went with a light application of OEM sealant on both sides. Really don't want to be this far into the 40's engine again anytime soon.I can't now recall, but I want to say I used just a very light layer of the sealant like @Michael B mentioned.
