FJ60 om606 swap (1 Viewer)
In fact, here is one such setup. looks to still be for sale even. And you both look to be in Alabama...
A few options really. Marks 4wd or advanced adapters Chevy conversion Bell housings, along with either doomsday diesel or speed gems Chevy transmission adapters for the 606. May be others.
Oh man, I am defi
Oh man, I am definitely going to check that out. Thanks for the find.
Trying to bring this thread back a little bit. I just got an OM606 and am planning on charging ahead with this swap into my 40. Does the OM606 to Chevy adapter put the correct angle on the transmission relative to the engine?
The engine will be slanted like normal for the 606. As far as transmission clocking, I believe 40s and early 60s had the trans level but 85+ were clocked down a bit more (?). I have not seen these adapters on person but assume they are configured to have the trans level.
DPUK’s H55F adapter should work with an H41/2 or H55F if you combine it with the bell housing from an 2H series diesel powered 70 series. That’s what I’ll be doing for my swap. My adapter should be here in 2 weeks. I’ll bolt it all together and update here and in my build thread.
Where did you find the bellhousing? I have been searching to no avail.
From what I have read it would work in a 40, the 60s make it more complicated with having to remount the trans. Not 100% on this though.
That would be amazing. Please keep us updated. I was planning on making my own adapter/flywheel but didn’t really want to if it’s not necessary haha
  • Back
