FJ55 Tailgate Handle
Colorado
It seems as though these iron pigs break a 'gate handle now and again......an easy replacement option: 1972 FJ55 Tailgate Handle by jrh00800 on Shapeways
On a '75 rig
Hey now. You think that was something they came up with out of the clear blue sky? What kind of material deposition is it?
First post.
3D printed 420 Stainless Steel infused with bronze, and has a final composition of approximately 60% steel and 40% bronze
It is heat resistant to 831ºC / 1528ºF degrees
Much stronger than the original handle
It'll last longer than the tailgate
Enjoy!
jrh00800,
Have you attempted the other piece of the handle yet? We've been trying to figure out how to tap the holes for mounting.
Enjoy!
while this is cool, if you are a vendor, you need a star to advertise.,,
there are a group of forum members working on this project for a while now. it would be nice if their effort wasn't totally usurped...you might try connecting with the guys over here...Tailgate Handle Reproduction?
cool handle BTW.
Do you work for Shapeways?
jrh00800,
@scrapdaddy The handle base: 1972 FJ55 Tailgate Handle Base by jrh00800 on Shapeways
I have not personally printed this part yet, nor tapped the holes.
I have drilled and tapped this material for another project and it is a real PITA but doable. This stainless hybrid material is super strong and when I tapped the last project I had to go with <50% thread engagement otherwise it was just too painful to try to tap. If you visit my link there is mention of the handle base which has two pilot holes. Also has info on tapping. It is up to you and possibly a machine shop or friend with machining experience to enlarge and thread the mounting holes.
I can modify the design to have two studs rather than holes that could be pinned or some other way mechanically fastened. Let me know if you would like to try something.
In a nutshell
Go less than 50% thread engagement for tapping the current model of 3D handle base.
Great job BTW to you guys on your efforts to make your own handle, I was not aware of this until @LAMBCRUSHER pointed out the thread. Very interesting to see your progress that paralleled my own.
The 3D images by @DoubleNickels are amazing, were these ray traced or something? You've even got the spring and the fasteners that is nuts!
I am not a vendor, I am just a guy who has made some parts for Jeeps, dirt bikes and now the iron pig that I hope helps people out.
This particular project came from a guy who got one of my jeep clips and thought I might be able to help with this handle situation. I started reverse engineering the broken handle back in 10/16 and it stalled when the guy who wanted it had some issues that prevented us from going any further. Several people have purchased the handle however and have helped to establish its usability. Thank you! And it is finally showing up on rigs around the net! Looks great @VIVA TERLINGUA can you post the pics of the handle on your pig though?
I apologize for not finding your tailgate creation thread and seeming to step on toes, not my intention. Very surprised anyone was even attempting this and truly fascinating to see the great work you guys were doing!
Another note: I noticed you guys mentioned polishing the shapeways part; the polished nickel steel is just a finish of the stainless steel material, polishing will remove the finish. FYI
Wondering if anyone has used these, can't find any feedback.
Product Description
Mounting holes require drilling and tapping of existing pilot holes
In order of tapping difficulty: 5mm drill bit (75% thread) / #4 wire gauge drill bit (50% thread)
M6X1.00 bottom tap
Shapeways Stainless Steel Tapping Best Practices
I apologize that there hasn't been any feedback until now.
Definitely check the tapping best practices, good eye @J Mack
In particular:
GlenG - You need to trust me when I say carbide tooling is the only practical way to drill, tap and machine this material. Slow feeds and plenty of lube. Playing with hole diameter would help. Expansion contraction is minimal.
gNSortino - Here is another update on this subject. I decided to test out the feasibility of tapping further.
What I did was create 3 small Shapeways Stainless Steel (SS) pieces with a .339", .34375" (11/32) and .375" (12/32) diameters. I put a slight taper on each of these to make it easier to start the tap.
I also wanted to test a straight imperial (non-tapered) thread to see how that worked as well. For this test case I created a 50%, 25%, and 15% thread for a 1/4"-28 UNF machine screw. This equates to a diameter of .2281", .23905", and .24343" respectively. Each of these also had a slight taper to help with threading.
##Setup##
For my tapping equipment I used a standard ratcheting tap wrench and the following taps:
1/4"-28 Cobalt Steel (McMaster Part # 25215A61)
1/8"-27 NPT Cobalt Steel (Mcmaster Part # #2662A26)
I chose cobalt steel taps because they have a Rockwell hardness between C30 and C45 whereas Shapeway's Stainless has a hardness of 20-25 ( https://www.shapeways.com/rrstatic/material_docs/mds-stainle ss.pdf)
I also used a drill press to align the tap in the hole. Very similar to this process here: . This was the first time I've used a drill press to align a tap and I found it did a very good job.
##Test Results##
I did the imperial 1/4"-28 (UNF) taps first starting with the 15% thread and moving up to the 15%.
All 3 threads were fairly easy. The easiest being the 15% thread and while the 50% was noticeably tougher although it was not what I would consider difficult. I was not concerned at any point the tap was at risk of breaking. As would be expected the thread on the 15% was barely noticeable. However, it would still mate with a machine screw and if screwed all the way in it would hold pretty well. The 50% created a really nice thread and the 25% was somewhere in the middle.
Next, I did the NPT taps starting with the 12/32" diameter and working my way to the smaller diameters. The 12/32" was very easy to do. It only produced a slight thread but it would mate with male NPT thread. The 11/32" was noticeably more difficult towards the bottom of thread. I stopped tapping with about 6-7 teeth still visible on the tap, which I believe is typical. This created a pretty well defined thread that mated very nicely. The .339", which is a standard "R" 1/8" NPT tap drill size was about the same difficulty as the 11/32".
##Closing Comments##
Based on these tests I would say that tapping Shapeways SS is definitely doable. I cannot say how much of an effect the cobalt steel taps or using the drill press for alignment had but I suspect they both helped significantly. I don't think the slightly tapered start had much of an impact but I also don't think this hurt things either.
While tapping I noticed that the chips were much finer that when you would typically see when tapping free machining metals. They were almost like large grains of sand. The material made a grating sound as it was tapped and even though the chips were smaller they still had to be broken (eg. back 1/4 turn for each turn forward). Also, the material did not get very hot like you would typically see when tapping something with a low heat transfer coefficient. I suspect this was due to the 40% bronze content.
Are these still available?
I ordered a set today, they say they'll ship out in early August. We'll see what happens.
