MoCoNative said:I've done some thinking on this. I started looking for timed relays, that would function like the stock computer/relay.
Here are some links: The first looks very promising as does the second one. I'm not a good enough electrical designer to tell which one would work from the third link, but there are many possibilites.
http://www.inpowerdirect.com/docs/PDS-60D.pdf
TDRSRXP-12V | Time Delay Relays
Search results for "time delay relay" - Allied Electronics
An adjustable thermostat can be obtained for electric cooling fans easily. For a blower, for those of us that never had one stock, or can't find one, I wondered if a Bilge blower would work. They are weatherproof, cheap and would move enough air I bet, something like this:
Bilge Blowers - Wholesale Marine
Just some thoughts, I'd like the timed relay, then I would know the fan could not possibly run all night if the thermostat screwed up or something.
What I've learned on this tread is if you have the cooling controller/relay the the wiring is most likely there and that the temp sensor is a simple contact switch to ground when the ignition is set to off and it senses some hot temp. It would be great to know what temp is comes on at (those with a temp gun and have them).
I believe a simple temp sensor with a deadband (so it does not cycle back an forth). Like on at 140 and off at 130F would work. I have the same thing on my solar attic fan on my house. Mount it close to the engine to replicate.
However I plan to go back stock and will be on the hunt for one. May have to bite the bullet and give $OR some more of my green.
I should probably fix it before I get stranded waiting for the engine to cool down. It is summer and all.
