numby said:Have you tried grounding the wire to the thermocouple to see if the fan will come on every time?
77mustard40 said:Here is where my sensor has always been located, this weekend I will pull it and test it with the Ohm meter and oven. The wires are a little frazled so I need to clean that up.
If it tests ok then I'm going to take your advice and mount in on the intake where the tab extends below the intake thus getting it closer to the headers. I think the loop at the end of mine may have originally wrapped around the air rail before a desmog (based on couple pics in this thread). Thanks for the input, I'll let you know how this turns out![]()
Fast Eddy said:I don't think that is the carb fan sensor. I've got a '76 and a '78 and they're about the same, and different than that.
I will pull out my electrical diagrams and chase some wired to report back.
now it's time to dig an old cooling fan out of a box and see it I can get it operational for starts on hot days ahead.
Pighead said:Are you running headers? Do you even need a cooling fan if you don't have an exhaust manifold bolted to the intake manifold?
78GroundUp said:Have time to consider the dilemma at hand I have a specific question this time.
Which wire (if known) tells the motor to "NOT" turn on. I just realized there has to be something that tells it not to? I understand the circuit completes itself when the key is off..... But there has to be a wire involved in that switching process....?? (thinking out loud)
I have worked diligently to not take any shortcuts.... Many hours and a few extra bucks to get this thing 78 operational. Would prefer to try and remedy this before going to a MOD.
Thanks to all who have input, specifically Fast Eddy who continues to tolerate me. (Insert smiley here) - I don't know how on my phone.
hey 78groundup looking at your picts I have noticed a few things. First take a fine bristle wire brush to the trace side of the board to clean it up and remove all the posible shorts. Then when you are done working on it and have it fixed just sray some clear coat on it for corosion protection. Hard to be sure from the pics it is not supporting glue but in pict 3 it looks like your electroltic cap has puked itself. If it has it will be at best weak if not open and will need replaced.Lastly in pict 4 - top right solder joint like it might a ring indicating a crack. Hope I have helpedOk in from garage...
Checked the carb cooling fan direct to the battery - it works
I have continuity to everything into the box and out of the box. Something inside issue box is not working??
Do you see anything I am missing?
(I have no idea what to look for here)
