The allen head bolts you see are 12.9 rated. When and if I bend one over, I'll install the 10.9 hex heads I have in my shop. The "bent" allen heads can be removed with vice grips.
As far as the hose is concerened, I've had my seal go out 3 times over the course 20 years. My experience as a mechanical engineer is that the hoses' primary purpose is to allow the pressure differential between the tranny and the transfer case that causes the fluid pumping past the bad seal to be minimized thus reducuing the amount of fluid being pumped and allowing for any fluid that is pumped into the tranny to drain back down and not eventually cause the tranny front seal to fail from over pressure due to eccessive fluid in the tranny. That hose is a steel braided -08 Parker Tough Cover with crimped fittings and adapters from McMaster-Carr. Far superior to the kits you can find at Specter Off Road or Man-A-Fre.
When I put the new Centerforce clutch in I will replace the seal. The hose will stay installed, as I believe that it will extend the life of the seal.
