If you are local, for an extra $1000, we can install it which will include the complete catback exhaust system that comes with a stainless steel high flow muffler and all new hangers.
2KCruiser,
Do you plan on offering a DIY kit that includes all the piping as well?
Since I like the way you think I feel I need to ask you how you feel about Methanol/water injection for these motors with or without your remote turbo setup. Would you ever consider adding a water/methanol to your setup? Thanks.
Here's an idea for keeping the intercooler clean from mud and all that: So the tried and true way of cleaning the undercarriage that we all know and use is to just set a sprinkler under the truck, turn it on, and forget about it for a while. Keeping this in mind, it might work to pipe a water hose above the intercooler and install a little sprinkler head pointed down right above the thing and then pipe a hose and fitting to the side of the truck. That way when it's time to clean the thing all you have to do is connect a hose and wait while the mud and debris melts off.
You were really ready with that one!
It's possible however the cat's have to be removed completely or swapped to a smaller high flow like mine to make it work. A lot more custom fab work on the brackets, but it can be done. I was originally going to install in place of the muffler however with all the room in the back, just made it easier.
