Video video video.....chanting on and on.
As Soon as I finish the exhaust I'll get some video.Video video video.....chanting on and on.
That is an interesting thought, I'll go check the cable to see if it looks melted.A friend had the same 2000rpm idle issue after a run. Turned out dustin's throttle adapter puts one cable too close to the exhaust and melted the inner core. It caused the cable to stick to the melted outer sheet.
Glad the firs t run went well, impressed you are running that much boost? What do you have done to the pump?
The fuel plate was slid all the way open and a 4k governor spring was installed, the timing was bumped to 16 or 17 degrees and I am running larger injectors and Mahle 286210 pistons.
It's suppose to rotate on the joints just not on the threaded part.I think that rod is loose, I can rotate it by hand. I'll see if I can tighten that up.
Very common on the toyota wiring to get low voltage at the solinoid. I wired in a relay for both the stater solinoid and that relay also triggers the relay for the fuel solinoid. No issues at all with it.I pulled the relay out and bench tested it, no issue there. I then tested the shutoff solenoid directly and it pulls the plunger up, no issues there. I then tested the voltage on the relay switch wire coming from the starter solonoid. When the engine is cranking I am only seeing about 9.5V at the relay. I assume that this is not enough voltage to close the relay.
I am not sure why I would only be seeing 9.5V off of the starter solenoid, perhaps a bad connection on the ring terminal?
What wire are you using as the trigger wire on the starter relay? Also what size relay are you running for the starter? I believe the shutoff relay is 70amps.Very common on the toyota wiring to get low voltage at the solinoid. I wired in a relay for both the stater solinoid and that relay also triggers the relay for the fuel solinoid. No issues at all with it.
I'm using the factory solinoid trigger for the signal power to the relays. I'm using standard 40A relays no issues. The pull on the fuel solinoid should only be active for 2-3 sec at a time when cranking then the engine starts and its relying on the 12v hold to keep it open. Only time you may have an issue is if your cranking it for a long perid of time.What wire are you using as the trigger wire on the starter relay? Also what size relay are you running for the starter? I believe the shutoff relay is 70amps.
I am going to do the same and wire in a relay to power up the starter solenoid and the pull circuit on the shutoff relay. That voltage drop on the starter solenoid has to be be caused by the large current draw required to turn the Cummins over. I assume the 1FZ has less current draw at the starter solonoid.I'm using the factory solinoid trigger for the signal power to the relays. I'm using standard 40A relays no issues. The pull on the fuel solinoid should only be active for 2-3 sec at a time when cranking then the engine starts and its relying on the 12v hold to keep it open. Only time you may have an issue is if your cranking it for a long perid of time.
My Isuzu was the same, had the dreaded click click of the starter with out the relay.I am going to do the same and wire in a relay to power up the starter solenoid and the pull circuit on the shutoff relay. That voltage drop on the starter solenoid has to be be caused by the large current draw required to turn the Cummins over. I assume the 1FZ has less current draw at the starter solonoid.
Well if you have the trigger going to the starter then to the fuel solinoid the starter maybe pulling enough power that it's not triggering the pull on the fuel solinoid.Weird part is, the starter spins great, it's just the jumper wire from the starter solenoid to the fuel shutoff relay that doesn't want to work with the lower voltage.
