bloc
Literally my only regret going v8 vs diesel is the lack of spooled turbo sounds..
You can put a turbo on your LS, piece of cake!!![]()
I hope so. We will see when I take it for the first test drive. Still need to inspect intercooler piping for boost leaks.Solid work Cim.
I think that will be next as my Ford could use some love. It gets driven like a rental and abused. My step son drove it to school the other day with the parking brake on. He called when he got to school and asked "Does your truck normally smoke from the rear wheels after you drive it?" He then asked "Was I dragging the rear tires as I drove?" Were we all that stupid at 16?Nice work!! I just went through rebuilding the Garret on my ford last night. Even easier than that holset above. No snap rings to deal with.
I am pretty sure I was. I remember driving my dad's 83 Bronco like it was a hotrod. I also remember getting stuck in the mud at night on private property a few times. This was before cell phones so it was a good walk to find a pay phone to call a friend with a 4wd to come pull me out before anyone noticed.Hahaha!! That's awesome. I don't think I was that stupid but maybe I was!
Putting off turbo rebuild for the weekend so I can bring it inside when the wife is working. My shop is packed full with both cruisers with no room for anything. So today I adding the fuel pressure gauge and changed out the overflow valve.
Before. Took the left banjo fitting out of the mix.
Snubber banjo bolt and gauge installed.
Old overflow valve.View attachment 1439747
New adjustable valve installed. It came preset at factory setting.
To remove the original I had to take out the set screw to have enough room to take out the OFV, which then fell behind the injector pump. I finally got to use the tool that Arnold used to pull the tracking device from his nose in Total Recall. I don't know the technical term for it so that's how I describe it.
Easy as looking at it with the hood up. It's just there to check every now and then. 30psi is stock I believe but haven't started it yet to see where I am at.Mechanical fingers BTW how do you read that fuel pressure Gage
No go there. I don't see the need for that.I meant, while driving![]()
What I would give to have 800 EGTs on the highway. Count your blessings and enjoy the truck.I got the turbo installed back in last night. I took it for a test run and boost is back and my weird noise is gone so that's good. My EGTs are still higher than normal so now I need to fiddle with the AFC housing. Seemed to smoke a bit more at wot as well. At 20-25psi of boost during 5th gear heavy acceration I am at 750-800 degrees at the downpipe. Not terrible, still in the green on the gauge but over 800 goes into the yellow. Im going to drive it to work today to get normal driving temps and see how EGTs are accerating on hills.
Your prope is on the manifold, right? Downpipe is +\-200 degrees cooler so it's deceiving.What I would give to have 800 EGTs on the highway. Count your blessings and enjoy the truck.
Yea, it's on the manifold.Your prope is on the manifold, right? Downpipe is +\-200 degrees cooler so it's deceiving.
