I've never used the Self drilling/tapping screws with rubber washer to fix a leak.. but I have used them inplace of bolts for tons of projects... no need to ever worry about a stripped out hole again.... I put togther the entire hardtop of my last FJ40 with these..... used two different sizes.. also used them to replace the upper and lower fenders on an FJ55. I use my battery powered drill to run them with a homed made extension that fits the needed sockets.
My last FJ55 had a header... kept coming lose... So I found the proper studs and studded all the bolt holes.... then bought a kevlar gasket and never had any leaks again. Also did this with the last water pump I replaced on another FJ40 I owned.
This one I got from running VW Baja's... Im just going to add it in cause you never know... We hit something that busted off the ends of both spark plugs on the passengers side of the engine... I found some bailing wire and ran it and duct taped it to the remaining part of the plug then curled the other end and stuck on the plugwire... it ran good enough to get me home which was an hour away.
Alternator crap out... running off battery? Ive rebuilt plenty of Alts... not an LC alt yet but this has worked good enuff to get me home... Pull the brushes and turn them around... or if you can flip them so the flat part is back down... this has worked more then once for me when I couldnt afford to replace the brushes yet..... I drove around in one rig for over a month like this before I finally replaced the alternator.
Cant reach an area to thread in a bolt or nut... use extra fuel, vacuum, etc.. line as an extension... works with spark plugs too..
Have a hole in the muffler from trail damage.... soda can cut in half and wire work till you can afford to get it fixed.... I've also used heavy duty tin foil..
Oh and dont forget to place antiseize on all suspension parts. They come off a lot easier the next time around.
