So i took off the check valve from the fuel vapor separator and pressure was coming out. Starting to think that maybe this check valve is either faulty, or possibly not really meant for this ‘74 1.5F engine.
I have read that there should be a little bit of backpressure thats why the check valve opens past a certain psi… is this enough pressure that would cause this wooshing im so concerned about?
Thinking maybe just removing the check valve out of the equation, what do you think?
This is the check valve I put in…
OEM fuel vapor check valve for 1/'75 to 9/'77 Toyota Land Cruiser FJ40, FJ55. Part # 90917-10020.
www.cityracerllc.com
Maybe Im wrong to assume itll work for the 74… wish there were psi specs somewhere
