- Thread starter
- #41
It’s unbelievable that they would have designed the pan with that tight of tolerance… it’s an oil pan for crying out loud… maybe they tried to make it double as a windage tray![]()
Yup, looks like they incorporated oil control into the pan. You’ll have to let us know the solution to using the ARP main studs if you go that route.
Of course it does you have to have the mains re-line bored if you switch from bolts to studs. At the power level you are going for you have zero need for main studs.Still going round on this. Machinist advises using bolts on the mains. He also says using non-stock bolts may require additional work on the bores. Frankly going non-stock on the main fasteners is starting to look like more trouble than it's worth.
The head studs, on the other hand, that's moving along. ARP is indeed considering an FZ set, and now have all the data they need. Whether that happens, and whether it's 12 long and 2 short or 14 short, remains to be seen. More soon I hope.
Ha, of-course to you; news-to-me. And that's exactly what he said.Of course if does you have to have the mains re-line bored if you switch from bolts to studs. At the power level you are going for you have zero need for main studs.
Ha, of-course to you; news-to-me. And that's exactly what he said.Apparently the bolts are typically reusable; he'll measure. I do like to overbuild when practical; I don't need head studs either, but why not when they're both stronger and cheaper...
Hmmm I’m planning to torque to head bolt spec, unless persuaded otherwise. I believe He-Who-Shall-Not-Be-Named torqued to spec, and he was S/C’d at the time. If that was good enough for him…I would say ARP head studs are a must, due to the head gasket, head warping, and head cracking issues the 1FZ has suffered from. Those that never allow the engine to run hot still have head gasket issues. Regardless, I believe the torque applied will be much higher using ARP studs, and more clamping force on an aluminum head engine is only a good thing. Not to mention the added strength of the studs, many of which exceed stock bolts by 20-50% in tensile strength depending on application.
If not building for boost, stock main bolts will be fine with seven mains. 2f or 3f I’d want ARPs for sure.
There’s no such thing as overbuilt. A work load that does not stress a component will last a lifetime. A component pushed continuously close to its working load limit or beyond is a stressed component, these components have short lifespans.![]()
Yes torque to ARP specs with ARP lube, they know their fasteners better than anyone on a forum.Hmmm I’m planning to torque to head bolt spec, unless persuaded otherwise. I believe He-Who-Shall-Not-Be-Named torqued to spec, and he was S/C’d at the time. If that was good enough for him…
I agree, follow ARP advice on torque specifications.
Follow the FSM on tightening sequence.
By changing a critical component, you've created a frankenstein. Not all the rules apply now.
Since we use Opel or Supra arps there is no specified torque spec from them.
On the diesel arp kits (1HDx) there is very specific instructions.
Cheers
In fact, people have been using studs that are too short, and they don’t run them all the way in. I wonder if studs you CAN run all the way in will eliminate the need to check and re-torque later? No idea…
They just kind of lost interest and drifted away. They did send me a custom set to play with, and they do fully seat and they are the proper length except for the front two of course. So I wound up having those machined down to fit. Works for me, but there is still no off-the-shelf set specifically for this engine. I will hit them up one more time and see what shakes. Maybe it was just a busy season and they couldn’t find the time…Any updates? I just checked on ARPs official site. New head studs for this application are nowhere to be found.
Bruh we all want these on the shelf awesome that you got a one off set lolThey just kind of lost interest and drifted away. They did send me a custom set to play with, and they do fully seat and they are the proper length except for the front two of course. So I wound up having those machined down to fit. Works for me, but there is still no off-the-shelf set specifically for this engine. I will hit them up one more time and see what shakes. Maybe it was just a busy season and they couldn’t find the time…
