- Thread starter
- #21
check out the videos and if you need to see something specific let me know
I had to keep the choke on when my fuel pump diaphragm was failing. I chased all kinds of carb theories before getting a new fuel pump from City Racer.
You appear to have a cracked intake manifold at cylinder number one?
[/QUOT
Are you confusing the engine working harder to increase in rpm?
If the engine is choked and it’s struggling to run because of it being overly rich then u push the choke in it evens out and runs high rpm
You need to adjust the carb
It doesn’t look like your pushing it in all the way either
Can it go further ?
If not ... that’s the issue ... it’s not kicking down from fast idle
My 2c
Btw I take it your tach is not working ... that high of an rpm is bad ... however it didn’t seem to move
Is this rig smogged? What’s the date on the carb?
