Brake/Hazard/Turn Signal Wiring Issues (3 Viewers)
Tucson AZ
Hello everyone,
I put a new OEM style wiring harness from Mark in this 1970 FJ40. I am now having an issue where the turn signal indicators light up when the brake pedal is pressed and the brake lights do not light up. The brake lights will light if the Hazard switch is pulled out, but the hazards do not work. All other lights work on the vehicle even turn signals when the hazard switch is pushed in. I have made a video(Link Below) any Help is greatly appreciated.
Vancouver, Washington
Hello everyone,
@kevos37
Has anyone talked to Coolerman? I hope he is doing ok. I have reached out to him but haven't heard from him. Maybe he's out of town. I hope he is doing well. Thanks
Jdc1
Akron, OH
I
Can anyone help on this?
I’d check your grounds and make sure they are on bare metal. Also, the system needs all of the turn signals/brake lights hooked up to work properly. Without the grounds hooked up properly, some crazy stuff happens, my fuel pump will fire up when I use the turn signal switch. Running ground jumpers helps too.
Tucson AZ
I
All the lights work, so those grounds are good. I'm wondering if I am missing a ground under the dash?
thebigredrocker
Don't know if these will help you figure this out or not. I know they are terrible hand drawings but they are for me not for publication. 🤣
This is a 1972 Hazard switch pin out. Hopefully you cut off the mating pigtail from the old harness to make splicing easier?
This is the turn signal switch pin out.
This is a 1972 Left Turn signal switch hook up.
This is a 1972 Right Turn signal switch hook up.
Tucson AZ
thebigredrocker
The drawings were Coolerman's. I assume you know, email is the best way to reach Coolerman.👍
Wish I knew the answer and could be more helpful.
Sorry you are having to go through all that mess! Here is a drawing showing the turn/hazard/brake. This would help you if you decide to use the hazard switch. View attachment 1685098
You will have to cut and re-route the turn signal wires in the aftermarket harness to the Hazard switch. Also it is CRITICAL that you feed the brake light signal to the OEM turn switch on the GW wire! Otherwise you will have turn signals, or brake lights, but not BOTH.
Here is the function of the Hazard Switch in the ON position. Note there are TWO power feeds! One is always hot and the other is Key Switched. This is so the Hazards can work with the key OFF.
Coolerman drawings from above quote
Long Island
Are they new tail lights? What happens when the brake is pressed at the same time as a turn signal? Does anything flash?
