Builds Bonnie (13 Viewers)
Speculums have limited use. Good for getting things out of a hole and I could see using to hold fishes mouth open to get a lure that’s been swallowed.
Either way the similarities are ironic!!
iu
Think I’ve got small slow leak from drain plug, copper washer didn’t work worth a crap.
Any good recommendations for better washer type?
What was on the old tank? Don’t recall any leaks from the drain plug. I usually used the white nylon/plastic/whatever ones on the rack at Autozone or similar places.
Tank wrestling for me was usually followed by a heavy dose of ibuprofen.
Well that’s the plug and old washer I have in it now. Gonna get new plug and gasket, use the stuff @J Mack recommends and I bet everything will be good!
Gaskets should not be reused whatever the material.
Might as well throw in pic I just got from paint guy with Bonnie’s other half “Clyde”
Finally!!! You and Kim and Bonnie and Clyde will make quite the Pig family. Let me know your schedule for pick up here. I'll try to get out and take a look in person.
First time I’ve seen the carpet I had installed. Lol, doesn’t look too bad.
Punkin metallic, same orange as many of the heeps you see driving around. Should have little sparkle in sunlight!
It’ll be a hit in the parking lot at OSU games.
