- Joined
- Oct 22, 2002
- Threads
- 168
- Messages
- 5,366
- Location
- Durango, Colorado
- Website
- www.durangomagazine.com
Poorly wired trucks can end up like this quickly. (Although not the actual cause of this fire). Fuse block is the way to go.
@LS1FJ40 thanks for the pics. Nice setup. Wondering if Anyone knows if there's a distribution block out there that I can use to run power from battery to multiple sources. The blue sea fuse block is a straight single terminal. I'm sure can wire more to it but I'd like to keep it neat.
I'll check it out Thanks JoeySwitchPro now. The added functionality makes it worth it.
This Blue Sea block attaches directly to the battery and includes a negative bus. It is sweet and I just got one for my Kimberley Kamper. The more I see and experience Blue Sea stuff the more I like it. Cruiser Outfitters can supply these items.
seriously? create a rats nest on your battery?This Blue Sea block attaches directly to the battery and includes a negative bus. It is sweet and I just got one for my Kimberley Kamper. The more I see and experience Blue Sea stuff the more I like it. Cruiser Outfitters can supply these items.
Do you guys not have the factory aux fusebox on the US models? They're standard down here in Aus on all models. Images ripped elsewhere from mud:
I run all my basic accessories off this box. Might snap a pic tomorrow. It's ready to go with factory wiring and a weatherproof housing. Only two things, my LED light bar, and my 20A run to a custom rear panel for other part-time accessories (IE, camping fridge, air pump), get their own runs to the aux battery (behind auto-reset breakers).
How did you mount your bussmann relay box?I've used Blue sea products for years, actually started using them on boats. There are very stringent wiring standards for boats, because an electrical fire on a boat generally means abandoning ship. Blue sea makes quality components for this environment which is also extremely harsh when salt water is involved.
Do a little research on boat wiring. The big difference with most boat wiring is that the grounds are all run as there is generally no metal frame or body to ground to.
I start with one of these at the battery
I prefer Bussman fuse/relay boxes that have 10 fuses and 5 relays. It is very tidy and allows for 5 fused relay circuits and 5 fuses circuits from on compact box. Read through this thread and you should come away with a basic understanding of how it all works.
DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Part 1 - Introduction [IMG] This is Part 1 in a series of tutorials that will show you how to build a Bussmann RTMR fuse/relay block. If you’re not...www.tacomaworld.com
I also build all my electric circuits to be easily repaired down the line. I rarely wire something direct from the fuse block to the device. Just like the OEM wiring in your truck I build in one or two sub harnesses so that if there is an issue you do not have to remove a circuit completely.
Draw it all out on paper first, you will be surprised at all the things you might have missed by just winging it. Always leave yourself a bit of slack in your harness to account for getting around obstacles between the fuse block and device. You also want zero strain on the harness at any point.
Run your harness in some type of loom and clamp the harnesses down EVERYWHERE.
