Busman (Eaton) also manufactures quite a bit of the Blue Sea Systems equipment IIRC. Quality products.
I make a plate that the box an one ground bus mounts to, then I make a lower enclosure to fit the spot I choose to mount the box, leaving one side open for the leads running to and from the box
Any chance you have a pic of that plate?I make a plate that the box an one ground bus mounts to, then I make a lower enclosure to fit the spot I choose to mount the box, leaving one side open for the leads running to and from the box
Only diesels got those. HDJ-81s etc.Do you guys not have the factory aux fusebox on the US models? They're standard down here in Aus on all models. Images ripped elsewhere from mud:
I run all my basic accessories off this box. Might snap a pic tomorrow. It's ready to go with factory wiring and a weatherproof housing. Only two things, my LED light bar, and my 20A run to a custom rear panel for other part-time accessories (IE, camping fridge, air pump), get their own runs to the aux battery (behind auto-reset breakers).
Any
I just got a bussmann relay box myself and Im trying to find some ideas on how to mount it
Pics?I just finished building a bussmann rtmr from that Tacomaworld link, and I’m interested to see how you mounted it as well. I’ve got a U.S. spec 95fzj so the charcoal canister is in the way of mounting it behind the battery. Only running the stock battery currently. Not sure if I want to mount it on the other side of the engine bay but might be the only option.
sleeoffroad.com
sdhqoffroad.com
huddexpo.com
+1 on all this...I've been running a custom version of the Bussman fuse/relay, those on battery terminals and fully loomed/bolted lines for 10 years with zero issues. Cry once up front when it comes to wiring...gets pricey quick!I've used Blue sea products for years, actually started using them on boats. There are very stringent wiring standards for boats, because an electrical fire on a boat generally means abandoning ship. Blue sea makes quality components for this environment which is also extremely harsh when salt water is involved.
Do a little research on boat wiring. The big difference with most boat wiring is that the grounds are all run as there is generally no metal frame or body to ground to.
I start with one of these at the battery
I prefer Bussman fuse/relay boxes that have 10 fuses and 5 relays. It is very tidy and allows for 5 fused relay circuits and 5 fuses circuits from on compact box. Read through this thread and you should come away with a basic understanding of how it all works.
DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Part 1 - Introduction [IMG] This is Part 1 in a series of tutorials that will show you how to build a Bussmann RTMR fuse/relay block. If you’re not...www.tacomaworld.com
I also build all my electric circuits to be easily repaired down the line. I rarely wire something direct from the fuse block to the device. Just like the OEM wiring in your truck I build in one or two sub harnesses so that if there is an issue you do not have to remove a circuit completely.
Draw it all out on paper first, you will be surprised at all the things you might have missed by just winging it. Always leave yourself a bit of slack in your harness to account for getting around obstacles between the fuse block and device. You also want zero strain on the harness at any point.
Run your harness in some type of loom and clamp the harnesses down EVERYWHERE.
