Builds Benjamin’s 3D Prints Build (74 Viewers)
If the lack of rigidity is with the part's material I can help out there. I just loaded a fresh spool of fiberglass. Just sayin. ;)
suprarx7nut's printer can print fiber infused Nylon which is much tougher than ABS or PETG.
I am considering to send the CAD model (M2 Variation) to suprarx7nut and he can print for people who want to buy.
Carbon fiber nylon *plus* strategically placed continuous fiberglass. Real close to aluminum strength if needed. I'm always itching to put that investment to use, so just let me know if you want to try out a run! :)
Nice! I am making M2 variant CAD model tonight.
Have you tried to install heat-insert for plastics on any part you printed?
A prototype
Not yet, but I've been trying to find an excuse to try it out!
Do those rigid lights have gobs of more output than the 9006 (if i recall) bulb in the oem fog lights?
The specs of D-series is here:
I don't find any brightness measurement in Lumen or Lux on Philips and Syvaania website.
Benefit of mounting D-series is various throw pattern we can choose, like flood, driving, spot, and hyperspot.
Printing a prototype and will test the fit on my LC.
Let me know and I'll place my order. I want to do of the dual 12v back of center console ones in tan and the AHC switch replacement/RAM ball in black as well. Assessing my rear cabin situation as well. Probably do one of the 12v/switch for the rear as well.
@geanes
@gregnash
Is this the mount you guys want?
I'm looking for something like this as well.
I currently have a tape deck mount but it will come out on extended dirt road trips. I would just need a ball to ball arm.
Also with the scanguage II mount, is there a way to retain the garage door buttons?
@Ayune may have a mount that retains the buttons
If you have a HomeLink Console like below them my mount allows you to retain the OEM HomeLink electronics box and fuctionality:
My ScanGauge mount (white plastic) showing the mounting of the OEM box and antenna:
Follow the link in my signature for more info and to purchase, or you can send me a DM.
Thanks, It's a nice mount but my home link buttons are right in the middle of that panel. I may just try and relocate them.
OK, i will read through the whole thread, its good stuff anyway! I will decide on a mount after I have scoped out all of your designs.
Cheers
Cheers
@mongoose2231 The first page has links and images of all the different makes. Start there.
Yes, saw that. Thanks Greg. I am leaning towards the Scangauge overhead with the two aux buttons.
