2000 LX470 build: help needed.
Northern CA
Hi all,
After 3 years of ownership to this 2000 LX470, I am READY do some real off road modification.
First batch order:
1. Metal Tech Rock Sliders
2. ARB Sahara Deluxe Bumper
Second batch order:
3. Warn VR EVO 10-s Winch (103253)
4. ARB Compressor (just the old brushed single for now)
5. BFGoodrich KO3 295/75R16 Tires
6. Bump-stops: Timbren Active Off-Road for rear, and Timbren SES for front
7. Whelan Engineering Pioneer Micro LED lights (3), some StrobeNmore LED light bars for front and back.
Third one :
8. ARB Safari Snorkel Armax
9. Midland MXT500 GMRS radio & 6db antenna
Any other suggestions to make this truck off-road worthy?
Thank you very much.
hskb
Progress Updates:
Install the ARB bumper and the WARN winch, still need to connect the electrical wires.
The bumper is good, but the ARB lights are junk (very cheaply made) , the only reason i went with them is for compatibility, but i need to look for a better ones now.
The winch is high so i need to relocate the winch control box, for now I ziptied it to the side, anyone has a better idea?
Below are the things had been done to the truck:
-- from previous owner with timeline and price he listed---
05/2018 NEW Driver's & Passenger Seat Bottom leather
05/2018 NEW Exide Battery
05/2018 NEW Ceramic Tint
05/2018 NEW All Weather Rubber floor mats-
05/2018 New Denso AC Condenser-
07/2018 New Toyota Tundra 18 x 8 Wheels with Michelin 275/65-18
05/2020 New LEXUS Steering Rack and Tie Rod Ends
06/2020 New Denso Water Pump, Timing Belt, Serpentine belt & Tensioner -
06/2020 New Denso Radiator, coolant Hoses, thermostat
06-2020 NEW Fan Shroud - $240 -
06/2020 NEW Antenna Mast, wiper blades
05/2022 NEW Wood / Leather Steering wheel
-- things i did ----
09/2022 new fluid
09/2022 new Odyssey ODS-AGM70 Extreme Series battery
09/2022 all new window molding trims
10/2022 Ironman4x4 270 awning
01/2023 New Kenwood dmx1057xr 10" floating radio with wireless android/carplay , dash & backup CAMs
02/2023 replaced all 8 Ignition coils, and spark plugs as preventive measure.
02/2023 added Air Down Gear Up SS1 sleeping platform.
02/2023 AHC fluid change
03/2023 new King springs KTRS-79
03/2023 new 4 AHC accumulators
03/2023 all new 4 arms
04/2023 add Autohome Columbus Variant RT tent
04/2023 Gobi rear ladder
I have the same winch and it’s technically under powered. But when used properly with a snatch block, it’s more than adequate. That said, I’ve yet to even install mine, I am just familiar with them in the field and use on our fleet at work. We are usually using some form of the EVO series.
Thanks whitec13, i don't know much about these, but the shop recommend this since it fix in the ARB bumper.
if I want something bigger, it needs to fix in the ARB bumper. thanks.
I have a 2000 LX470 also. Didn't see it mentioned but I have a full set of BIOR skid plates on mine. Mike put them on for me. They're heavy but weren't that expensive and i've never had to take them off for service.
so after some more reading on the forum, I decided and ordered the following:
5. Falken Wildpeak A/T4W or BFGoodrich KO3 285/75R18 (need to do the mod described in this forum first before going to a local tire shop)
6. bump-stops: Timbren active off rear, and Timbren ses front
Man, the list goes on, this is a $ pit Lol
Just ordered
8. ARB Safari snorkel Armax
9. Midland MXT500 GMRS 50Watt Radio and 6db Antenna
Installed the bumper and winch last Friday night, and went to Pismo Sand Dunes in the wk (bought my 1/6 RC scale crawler with me as well ) :)
