ha ha not where this old FJ40 goes.
One thing to keep in mind is if there are any regulations that specify tool dimensions.
During fire season here, if a declaration is made that a certain area is under fire protection rules, you have to have five gallons of water, a full size ax, and a full size shovel. There are actually specs for this:
"Possessing the following fire equipment while traveling in timber, brush or grass areas may be required: one axe at least 26 inches in length, with a head weighing at least 2 pounds; one shovel at least 26 inches in length, with a blade at least 8 inches wide; and one gallon of water or one fully charged and an operational 2.5 lb or larger fire extinguisher."
(From Oregon Department of Forestry Protection from Fire )
Treat "...may be required..." as absolutely required during fire season. Also, there are minimum specs for using a chainsaw in the woods (see link).
The Oregon Dept. of Forestry outlines their minimum requirements for the shovel and axe.
The USFS and BLM have been specifying 5 gallons of water dedicated to fire fighting, so that supersedes the 1 gallon spec by ODF.
The minimum universal size of fire extinguisher appears to be 2.5 lbs.
Note that the feds want water AND a fire extinguisher, while the state specifies one or the other.
Some localities specify carrying of a water bucket as well. There has not been a spec whether it has to be rigid or collapsible, so the reproduction military cloth buckets work well as space savers.
And yes, the county deputies and Forest Service, BLM et al can and will check and issue tickets for this.
There can be local rural fire district rules and open fire rules for campfires in the non-fire season.
To recap for Oregon:
(1) Ax, two pound head, 26" handle minimum.
(2) Shovel, 8" wide blade, 26" handle minimum.
(3) 2.5 lb fire extinguisher.
(4) 5 gallons water dedicated to fire fighting.
(5) Bucket
So you can see, a folding shovel and hatchet are nice to have on board, but there are regulations that specify full size versions that can go into effect anytime in the summer and fall. My advice is to start checking your state requirements. I'll bet many in the west are not far off from the above list.
did you drill the glass for mount the axe????![]()
it does look like its hanging in mid air
Double take for me too.did you drill the glass for mount the axe????![]()
Sheez I had no idea they had regs for that. Thanks for the heads up, I'll have to check out MT's regs, if there are any.
Oh and here is my setup. I finished it Saturday.
