Builds An HJ61 followed me home to Texas (26 Viewers)
I also wire wheeled and painted the dump pipe. Cut ear plugs made it in this time. Note the fancy paint booth: a wire loop hanging off the front bumper.
Finally getting to work on the 12HT a little. I ordered another pyrometer from ISSPRO for the 79 pickup build, and this time got the long 1/8” NPT probe. It protrudes into the exhaust, not all the way to the center, but this should be adequate, I assume.
Bolted on the exhaust manifold with OEM gasket, new nuts and bolts.
It feels good to put that stupid manifold back on because waaaaay on page 1, I initially just took off the exhaust manifold to replace broken exhaust studs.
Seems like things got a little out of hand since then.
The same nuts hold the turbo to the manifold and the dump pipe on the turbo. @Unoman dropped by with Bug, who supervised putting the dump pipe on the turbo.
Cleaned up the turbo water line and used new hardware there as well.
I panicked because I could not locate the dipstick, flywheel bolts, or these water and vacuum bypass lines. I found everything but the lines, which is maddening. Luckily I can just use soft lines if I cannot end up locating them. Frustrating.
Moral of the story: don’t wait 2 years between starting and ending a project!
I ended the day by putting on the 12HT sticker I got from Decaldog.com. I was going to wait till the very end, but it’s gonna get covered up by more stuff. So, today was the day.
I was able to get out to the barn tonight for a few hours. I found the turbo water bypass line. Someone, probably one of my kids, threw a whole bunch of Halloween decorations on the 12HT shelves, and the line was tangled in a bunch of stupid lights. At least I found it.
I bolted up the turbo with its associated oil and water lines. The turbo waterline hose is NLA, but one from the 1Hx series of motors fit just fine. It was a bear getting the bottom water bypass pipe to fit the car, as it had gotten all bent out of shape. I had to release the V band between the turbo halves and rotate it out of the way to get everything to line back up.
All in all, I found all the parts, everything fits, it’s bolted up, and it’s one less thing to put back on the motor.
The weather is cooling off here in Texas, it was a beautiful Saturday night.
Hot find from @Racer65 ’s treasure trove of goodness. OEM 62 driver’s seat belts!
One each...or if the 62's driver belt is good enough, one stays on the shelf!
Looking good Galen!
Finally started putting mine all back together, had the same issue ... pulled the exhaust manifold to replace the rings, ended up being a longer job that I had originally planned!
Keep up the good work
I sourced a set of heater hoses from Australia. They got here in about five days! Pretty stoked.
And in a moderate amount of sacrilege, I ordered a couple of tubes of @roma042987’s favorite sealant, Hondabond. Don’t hate me.
Dude, you join social media, get me all excited, and now I’m gone for life. Fark.
Who am I going to call for obscure parts for a 15-BFT???
To recover from the emotional trauma of having @Onur cut me off, I got the water pump installed. Since the OEM clamps are NLA I dug into my stash of @Racer65 stainless clamps that I bought about five years ago. They rock.
What a beauty!
You’re doing a great job mate!
1984 BJ42, frame-off restored, factory 5spd tranny, 4E9 Toyo beige
1983 BJ45 P/Up, factory P/S, resto project
