What are the effects of the canister not working properly?
I was having the swoosh as well and just swapped the two same size hoses on top of the OEM CC to bypass the internal check valve. No more pressure build-up. It took less than one minute, cost me $0 and the amount of fumes and fuel smell I get with the CC routed this way is negligible.
I think this is the one installed. I'll take couple of pics after work and post for reference.Hi everyone, i just got an 87 fj60 desmoged and noticed that it doesn't have a charcoal canister... looking through other threads ACDelco 215-153 GM Original Equipment Vapor Canister is being recommended, i want to try it out, I am getting tons of gas smell and saw in a thread that this is the issue, looking at vc120 it has 3 ports, 1 is plugged and 2 are open, what hoses do i connect to it, where should they be coming from?
Thanks in advance
That same symptom is present on 62s as well. My tank was getting way overpressurized. I did the line swap on the check valve before my tank ruptured. Going to try the Berryman B-12 trick in the check valve and see if that frees it up. If that don't go I'm swapping in a Delco unit.Strictly speaking, no you don't need it. It does help the tank vent properly while reducing fuel fumes and odor though. Unlike the other emissions components, it doesn't rob power and in fact may increase mileage slightly since fuel vapor absorbed by the charcoal is released and pulled into the intake where it can be burned.
As for whether it's still doing it's job, you'll have to determine that. On the 60's, the tell-tale sign that it's had it is that there's a pronounced "woosh" from the gas tank when you take the cap off to fill up due to excessive tank pressure. For $60, I think it's well worth just throwing on the AC Delco. If you decide to ditch yours, make sure your tank has a way to vent.
