Registry 8x Series V8 Swaps (1 Viewer)
I just tried this tried this old air filter out in place of the stock airbox and the power difference is unbelievable. Now I need to work on making up a bigger airbox for this thing that will work with a snorkel. Looks like there is a company in Australia that makes a nice set up but I imagine that shipoing is going to be a motherfuker
All about pumping air Steve!
Long time...
I've just seen so many posts where people said their stock aurbox was sufficient. Must be on 5.3's with stock tuning or the guys just don't realize the potential they're choking off.
It is pretty straight forward. This is a 62 set up, just cut off the top leaving enough to get an elbow and clamp on it. 4" straight through. The bellows section is not doing airflow any favors either. I know that it is off the OEM set up but smooth tube creates better flow.
This is a crate 5.3L in a 62
That looks nice. Have u done any drive by cable swaps?
That's what I read too. But I just bought a 93 cluster for 50 bucks so I will probably try to avoid using this module. I got ahold of a complete elocker setup, and the newer gauges have the locker lights.
i swapped tac. with one from 1996 and it is working now seating on dakota digital is IN-4 cyl OUT-6 cyl 519 set to LO and output signal on HI
Absolutely agree... I saved several hundreds dollar going direct to Marks.
Thanks for this advice guys. I just ordered my adapter from Marks yesterday, and DHL says it'll be here four days from now. Saved a couple hundred bucks vs. AA.
Hello,
Unfortunately, the problem continues. I installed a corvette’s manual transmission program, but the issue is still happening. When I accelerate, it does not pass the 4000 RPM, but if I cut the ignition and turn it on again, it works perfectly. And if I cut it and leave it a few minutes, it stops the issue when turning on again
Was wondering about towing with a 5.3, if you put a 5.3 in your cruiser and have towed with it were you happy with it or wished you had gone 6.0? My overland trailer weights about 1800 pounds and I was wondering which motor, 5.3 is a lot cheaper just wanted peoples input thanks.
