Builds 86 4runner build (2 Viewers)
Looking forward to how you do wiring harness.
Are you gonna remove counter-balance shafts?
Taking stuff off the 3rd gen. I'm really struggling leaving the motor alone. I'm losing the struggle. Took the valve cover in to work yesterday. Ran it through the jet wash, baked it in the oven, ran it through the shot blaster, tumbled it, washed it again, blew it all out, painted it in wrinkle finish. Got a new PCV grommet and ordered PCV valve, and a gasket with spark plug seals.
48 hour wait time to handle, so Friday I'll file the paint off the T.
Took the intake off tonight to take in tomorrow.
Exhaust got shot blasted, painted with 1200 degree satin clear. Cured it in the oven so hopefully it'll last. The heat shield came off in on piece too, so it's not like it'll be visable at all.
Intake got washed, baked, washed again and then painted with the wrinkle finish.
It's a 2000, so the marlin 3fz thread says it's a COP with a very simple harness. But it's a non-CA model, so it's not. The rest of us got the 1999 version one more year. Also, that thread is about wheeling trucks. They seem to cut out cruise control and AC, both of which I'd like to have. So I don't know how much interior harness I need.
So I took most of it.
Does this have an engine harness that integrates to the cowl harness? How much of the cowl harness is used on the engine?
don't forget to adjust the valves, the exhaust side tends to tighten up over time. can you share a picture of the ECU? you may have seen my swap thread liveoaks 3RZ swap
best mod i've done.
oh wait, you did mention checking the valves. Sorry about that.
Interesting. I am probably re-powering in the long run, but have coil-over towers to contend with now... :cheers:
After setting the intake and exhaust on and putting a tape to it, the 3rz is about 3.5 inches wider.
All on the intake side, I would guess.
