1987 22RE 4Runner
what do the idle air valve and hoses look like?
does it straighten up if you blip the throttle?
They are new. I have sprayed carb cleaner around to check for leaks. Nothing. It takes a bit to warm it up. As of today. When I warm it up she runs ok. Idle still not where I set It. Frustrating.
I have also tested the cold start injector plug ( brown) it’s within range. It says .30-70 ohms. It’s right at .30 ( maybe not
Good? I have replaced the ECU green switch.
