60
MI
Looks great. Usually rust is the biggest concern with 60 series. It doesn't seem to be an issue with this one living a desert life. Oil leaks, condition of rubber lines and gaskets would be worth checking for, I guess.
WOW, H41 in a 60 series.
X2 to above
Looks like some paint bubbling on driver door and overspray inside fender. As said before, I would just look for rust and evidence of poor rust repairs. If there is not much and you get it for a decent price you can't go wrong.
Odd they painted near the data plate under hood. Look for damage on that side. Rear bumper looks out of alignment, look for damage around the rear . Both could be nothing but look for damage in those areas.
More delays.. still working through process. -
Few.more pics little more detailed may be à few diff posts due to amount bit want to capture
Part of deal bt radio and paint lol..
No tellingbhow old the tires are. They do have DOT on them but are tubed on 15in split rim
AC is added later, not factory. owner did have accident earlly 90's on left side, repair and repaint. owner stated it was previously Jordanian Military vehicle and he purchased from gov around 876sh and restored with pieces from two others out of Saudi Arabia.
still waiting on all the pieces to come together. looks like it will need tires too. not sure if I should keep split rims or move to bigger wheel size and radials. understand you can run some radials on splits.
Split rims weigh a ton - I would ditch them for a 1-piece rim.
That paint cracking is often a sign that someone used a large amount of body filler and painted over it....and now its starting to fall out. Don't be surprised if there is some nasty rust hiding under that suspect paint.
will check again, didn't look like any rust on body that we could tell. thinking they just resprayed everything years ago with little prepwork.
truck has only ever been in desert climate here in Jordan, only rustbuckets I have seen are the bedhouin trucks that are rode hard and put up wet, literally.
update: truck is in shop for paint / repair. may have to put as build thread. starting issues with choke inop.
white white white. today received call, ready to paint.. grey it will be. new color will be LA7C. Moonstone Grey
before traditionalist jump all over: last 6 vehicles have been white, not included in that is a model Y and Kia EV6 in the driveway, both white. sick of white cars constantly.
looking for wheels now as the split rims and decade+ old tubed tires are/were squirly under braking. found some hilux rims, but looking to see if I will need spacers. hub bore is 112, so that part should work.
