- Joined
- Jul 22, 2012
- Threads
- 582
- Messages
- 16,365
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Yeah, OK.![]()
I was doing some light reading and came across something from Nostradamus that stated a 1fz-fe with a turbo and a750 transmission would make an LS swap obsolete.
That's awesome. I don't doubt it. I only dabble in box #2 so no practical experience on the rest.
Georg is a bit more reliable than those jerks at northwestfab who claimed the doubler is right around the corner.This would be VERY interesting!
I literally just saw that on Facebook and jumped on MUD to see if there was anything else. Unfortunately no
I'd love a 750f in the cruiser.
One thing to keep in mind is the 750 pan is much wider. With an hf2av, getting a CV front driveshaft in there is a challenge. Toyota stock CV will not fit when stuffed.
Source:hammersaurus lex
Not easily. Maybe a teensy bit of trimming of the lip but I wouldn't bother.Well that sucks!! can the pan be modified so it will fit?
Then you're screwedWell, I'm not going to a non-Toyota CV... so there's that..
Can you expand on this a bit? If using a a750f along with the hf2a from a 100 series, is it because of the compression of the axle on an 80 series that causes the issue? Where on a 100 series the driveshaft stays in place? Or is it due to actually using an hf2av which has different spacing than the hf2a?
