Builds 3RZ / 2RZ Swap Notes
This may already be known, but as an update to the 2rz/3rz swap into an IFS truck, I have information from another mud member that you can use an oil pan and pick up tube from a 3rz equipped Landcruiser Prado if you can locate them internationally. 12101-75080 12101-75090 oil pan. 15104-75090 pick up tube.
15301-75011 dipstick.
This may already be known, but as an update to the 2rz/3rz swap into an IFS truck, I have information from another mud member that you can use an oil pan and pick up tube from a 3rz equipped Landcruiser Prado if you can locate them internationally. 12101-75080 oil pan. 15104-75090 pick up tube.
I used 12101-75090
Is this confirmed found a good deal on a t100 with 3rz.
Used Toyonly swaps motor mounts and w59 bell housing and ors wiring harness. Good to go after that.
Hey thanks for replying. I'm going to be picking up a 95 2wd t100 stick shift. That bell housing off the truck will mate with my 86 tranny correct
Info for anyone in CA trying to get through this engine swap
This is the email from the ref on my first virtual appointment
Please reply to this email with the following:
Pictures of the engine installed from left, right and front of the engine bay.
Pictures of the EVAP canister.
Pictures of the exhaust configuration including catalytic converter & O2 sensor locations.
Pictures of the ECU ID
Donor VIN
Pictures of any CARB EO's & part numbers for aftermarket parts.
Vehicle registration
Pictures showing a functioning check engine light.
An invoice from the manufacturer dealer or licensed automotive repair dealer (ARD) verifying in writing that the ECM/PCM programming, functionality and CVN and Cal ID is correct for the donor vehicle.
Picture of a scan tool screen showing that all OBDII monitors are set to ready with no DTC's stored.
Thank you,
So did you get it bard and what did you do
My truck is now ready for the CA BAR ref to check and I have a virtual appointment on May 1st.
Two of the items they are asking for
1. Deaker invoice for PCM/ECM programming (if applicable)
2. If 1996 and newer, needs software verification of donor engine
Does the ECU need any programming, it came from a different Vin as the computer in the vehicle the engine came from was damaged but it did come from the correct setup, 3RZ 4x4 manual trans.
So how could one do a software verification of the donor engine
Does anyone have a little more info for me to work with prior to my appointment next week.
Any updates?
So the flywheel needs to be from a 3rz and clutch? Or 3rz flywheel and 22re clutch?
Match the flywheel to the engine. Match the clutch to the flywheel.
I went all 3RZ clutch parts. Including the slave cylinder. It keeps it simple and ensures that everything works as close to factory as designed.
Ok so I'm still debating this swap. I've never done anything remotely close to this and I'm mechanically inclined but... so I've kinda go a list of things. The reason I'm considering this swap.
Truck is 22re with 230k miles pretty sure nothing has been done to it. And I am losing a bit of coolant as my resevoir goes empty. Bug no white smoke
I plan on moving to hawaii next year and this truck will become my daily out there and I'm unsure of any reputable shops that will rebuild my engine if it decides to go.
So my 3 options as I see it is
1) Have Yota1 rebuild my engine either stock rebuild or stage 1
2) Have someone install new head gasket and timing chain
3) Do a 3rz swap
I've made my list of items I'll need my father in laws neighbor in socal has a rolled 99 taco with a 3rz auto he is willing to let go for 800. I would take the catylac converter engine air box etc from this
Parts needed
Or's battery tray
Toy only swaps mounts
Or's wire harness
99 4x4 taco ecu
W59 bell housing
Prado oil pan
Prado dip stick
Prado pick up tube
Heater valve 87240 89124
3rz flywheel and clutch
22re fork?
Custum exhaust?
Resistor for gauge cluster
Can I put a 89 ac compressor fittings on the 99 compressor.
If I'm missing more things please let me know
