SR5 Cluster swap fuel gauge help
as long as the wire is there its gravy.
otherwise you will need to add the wire from the cluster to the sender. but its simply just that one wire. it works like the sender. power from the key, through the light and grounds through the sending unit.
that diagram i posted above shows it
Yup that's what I was expecting... I know the wire exists on the back of the cluster so if not wire is there at the fuel sender I'll run a wire and splice into the yellow and blue wire going to C10.. Thanks!
are the part #'s for the sending unit floats the same or different ?
there are several different potiemitor values in the late 70's all 1980's and into the mid 1990's TOYOTA trucks speaking ...
@gnob DOES know his $hit. And you were very methodic trouble shooting. Good teamwork. (To all those who contributed) Even better that it isn't a dead end thread. 👏
I warms my old heart when folks come back with solutions. Too many times we get "I have a problem," we all chime in, then never hear back. Glad the gauge is working.
