Build 3RZ / 2RZ Swap Notes
someone just posted this site. this pan is showing but may or may not actually be available.
might be worth an email.
I’m personally responsible for multiple websites adjusting their inventory to reflect that it’s been discontinued and can’t get it from the supplier. I forgot about Impex. I’ll give it a shot, thank you!
Struck out. On the bright side, Impex now has a recently updated inventory I guess. The search continues.
For those with swaps and the AC working, what’s your normal idle with the AC on? Mine keeps dipping down to 500 rpm and sometimes will bounce up to 900. I’m thinking my resistor may have gotten messed up when I was wrapping my harness but I just want to confirm my suspicions before unwrapping all the wiring.
I'm glad you got that far. I can't get mine to do anything.
No tach on mine so I can't give hard numbers but mine raises when AC is turned on, I'd estimate 150 rpm or so. If you like I can try to run it up to the shop next weekend and hook it up to my timing light and give you some actual numbers based on the lights tach function.
not to brag but my AC works fine, for a 4Runner anyway. Idles up as it's supposed to, no dips or surging in rpm's
I wish I could figure this out. It's wired the way you instructed.
If you’re already going that would be awesome to get some numbers. I’m planning on checking the wiring in the next week.
Did you end up using the 3rz AC compressor or did you use the MR2 clutch on the 22re compressor?
3rz 4R compressor.
Question for those with a bit of knowledge on the 2/3RZ's.
Struggling to find a 01+ 3rz donor truck over the last year or so. I found a 3rz long block with a blown head gasket (planning to do a rebuild on any engine I get anyhow).
Are all of the accessories and engine bay components the same on the 2RZ trucks of the same year w/ manual trans which should be much easier to find?
