- Thread starter
- #21
Thanks again for sending me the modified schematics, Russ. I think I was able to successfully connect everything following your notes with the exception of the (BY) charge light relay wire from the alternator.
Can you explain why you connected it to the (BY) ignition wire?
On a related note, since the FJ40 has no charge light on the dash, can I just delete the (YW) charge lamp wire (from the alternator) and fuse from the panel?
Here's where I am at right now:
"HOUSTON, WE HAVE A MESS"
This is probably the scariest part so far. I decided to reuse the FJ62 fuse panel and modify the FJ40 mounting brackets to accept it. This is so daunting at first it's easy to think, "I'll never get this running". But, even when I get completely stumped and aggravated, usually all it takes is a 15 minute beer break and when I come back with a clear head, I have (so far) been able to figure everything out.
I'm also going to use the two circuit breaker mounting points to hold the "ignition main relay" and the newly added "switched power ECU ignition relay" <--- see 73tlcv8's notes above. to the fuse panel for neatness.
The ignition main relay is unaltered from the FJ62 schematic, the switched power ECU ignition relay has been added to take some of the load off the stock 4 wire ignition switch.
Now, I'm down to trying to figure out how to mate the FJ40 tail lights, marker lights and brake lights as well as the front headlights. The FJ62 used relays for all these components while the FJ40 did not. I don't think it's worth the effort to add relays for the rear lights but I definitely want to add a pair of relays for the hi/low beam circuits up front. I've got a Painless relay harness kit incoming so I'll be playing with that very soon.
The only other thing I've been working on is the Autometer gauge kit from Amateur.
I've got everything mounted except the gauge cluster faceplate since I'm having it repainted. I've also painted the speedo needle and fuel gauge needle white to match the autometer needles.
Yaya!
Yaya!
