200 Series Portal Axles (9 Viewers)
Will be interested to see if there's some insight into why the aluminum failed at the LBJ? Leverage on the tire, but is that a manufacturing defect (i.e., not design). My 4runner has fully fabricated and boxed steel knuckles, I never thought twice about the lower joint ripping off...
Interesting 🤔 I wonder if the werewolf portals have a similar stipulation on their warranty. 38’s are lame 🤐
74Weld Warranty depends on the vehicle and axle splines... some are up to 40" tires.
Werewolf Portals:
"Portal gearboxes are guaranteed for a period of 2 years or 50,000 km, when using wheels with a total diameter of up to 38 inches. And for a period of 1 year or 10,000 km, to the use of wheels with a total diameter of up to 40 inches."
Werewolf Portals:
subtext, "yo shiit gonna break son"
They're speculating over on the Bronco forum. Sounds like 74Weld is stepping up to help them out. Also the Bronco guys think it's a little weird that it just broke like that. Apparently there's another Bronco and a Toyota that broke their portals, both at KOH sounds like but not sure. And the Toyota seems to have been installer error.
The one user that seems extra upset has had some issues with his own portals:
I'd be upset at breaking my $25k portals, but having been deep in the rock crawling world, breaking stuff happens. Even "unbreakable" stuff.
It's true. I only do occasional crawling now when it's part of the trail to a destination. I couldn't hang with my Jeep friends anymore cause they love pushing the limits and breaking stuff on hard trails. I was always like man I can barely afford to get this thing kitted out, I can't buy things two or three times.
Especially if it's a BFG 38 that measures in at 33" actual diameter haha
jk jk
From what I understand the Werwolf’s have a brace right where this failure point is that 74’s don’t have.
So, lmtl3ss_or on IG and @wind_chillin_taco both are running Werewolf Portals (38’s and 40” tires respectively) and both just did all the toughest trails at KOH without issue. @wind_chillin_taco has also done several long trips over 12 hours with his, did the trails, drove home, and no issues.
Have you heard of any failures on the werewolf setup?
Yes, but it was the result of improper installation, so I don’t know if that counts?
When/where was the Werewolf failure?
Just curious to read up on it.
Bronco guys are reporting another 74Weld failure at KOH
I’ve heard of three 74 failures at KOH. Is this another one being reported?
Not sure about the Werewolf issue. I only know it was due to faulty install.
I don't know if it's an additional one, maybe you already saw this one? They said it happened 4 days after that one you posted last week. Just saw it in the latest Trail Militia video - it's on their Bronco. Skip to 31:30
Sounds like they have to be careful with Bronco suspension setups and when the aftermarket heim tie rod end bottomed out it acted like a lever and broke the mount.
As much as i want the werewolf portals too rich for my blood. I'm gonna upgrade the necessary components and run 35s for a quarter or less of the price. I know it's not 38s/40s but I have another toy to remedy that. Love watching the guys that do get it though.
You can do A LOT on 35’s!
Some good portal 4lo² action in this vid. As much clearance as these portal rigs gain, stability does seem to give up some. There's trades to everything and need to decide how a rig is going to be used.
Gramps with the GX550 is too cool for school.
I was waiting for that video to come out to see @Broski in action winching their 250 out of the escalator. More Broski action at 24:40. :cool:
After watching those rigs on a trail I'm very familiar with, I'll say, I think I'd prefer my stock LX suspension (or a normal lift) and some good skidplates over the portals. Seemed like a lot more tippy/floppy and side to side sway than a normal rig would have. Best use for portals is maybe romping through the muddy forests like the Ukrainians. Sure looks awesome though!
Saw an LX on 40s at COTR. Very cool but also wider on trails which meant driving in ruts could put it off camber and the wider track width means taking the same lines might not be feasible.
Portals provide gobs of clearance though. But for the $ I’d just go with the effort to fit 37s and be done with it.
