200 Series Portal Axles
Globes are new and flush was recent btw.
My first vote is for a stiffer rear swaybar and possibly a custom front swaybar next. But I’d like to hear from others. @PADDO have any opinions?
Ok AHC experts. Did a shake down run of the portals and 40s and swayed like a boat in a stormy sea, and bottomed out just going up steep inclines. I’ve added westcott preload collar lift already for support, and LX 450 rear springs (higher spring rate).
Have I just exceeded the capacity of AHC? What say you??
I don’t think it’s exceeding capacity, more like physics. The wheels are in a very different place, creating a much bigger lever.
preload / rear springs and maybe thicker rear sway bar would be my recipe to start.
This is my guess as well, mostly with the front suspension. The distance between contact patch and original hub centerline suddenly got 25% larger, even coming from your existing tire/wheel setup.
Yes I think it’s the leverage. But it’s not just with the front. I’m bottoming out in the rear just going up an incline.
That has me wondering if there's anti-squat built into our rear suspension that is going haywire due to the new hub centerline.
Does it do it under throttle or just with an incline?
Can you explain what you mean by bottoming out? Like hitting rear bump stops hard? Are your bumps still stock?
Motion ratio especially front axle. Meaning the tires are much much further outboard. I'd go so far as to suggest using OEM 200-series LC front springs.
This can be calculated too. How much further out are the hub faces?
Rear axle doesn't work the same so your uprated springs are probably sufficient there. Though a heavier rear sway may be useful.
74weld on record focusing current development efforts on the LC200 and 2nd gen Tundra
This ended up being caused by a bad tone ring. Threw the entire AHC out of whack because it couldn’t determine wheel speed, so it went into limp mode.. Easy fix, but I’m deleting AHC anyway. It’s time for an offroad specific suspension.
Glad you figured it out. And kudos for continuing to push the platform!
Glad to see they’re making progress. I’ve been periodically bugging them about it lol.
Not sure how different the new LX700h AHC system is compared to the LX570, but Dissent seems to be running their portals on the stock AHC without any issues.
I’ve been bugging them too. Quinn told me this quarter for the 200 Series portal set.
The difference is that it is even further integrated into everything. You really can’t delete AHC without compromising every other off-road and safety feature (MTS, VSC, ABS, Crawl Control etc.). So the portal companies have to be sure their portals will work with AHC.
Hey guys,I worked here at 74Weld, and this is true.
This is actually want I came here to ask you guys, just out of curiosity. How many of you would maintain KDSS and stock suspension, and for LX owners the AHC. Really just out of curiosity here, I'm excited to see people maintain those systems while running 37-40s because I think thats rad, but I'm curious if thats a priority for people.
I’m unlikely to drop the $ for portals but if I did I’d try to keep the KDSS
I would think it would be a priority for most people, seeing as everybody loves kdss and (to a lesser extent) AHC. But I can't even imagine the numbers--seems as much as we drool over portals, only very few would actually put up the money to install them.
I might get portals in a few years (making my LX an offroad-dominant vehicle). If I did, I'd prefer to keep the AHC, unless it's not practical.
