FishTacos
Full Globetard
That's beautiful. Great work VV.
Uh , done means installed , lol . Looks good though. Sarge
Ok, 15 minute rule. Do I remove the flywheel to get the bell housing off? (If you can't find the answer in 15 minutes, ask. It's been 45).
Do I leave the flywheel on and loosen the crankshaft nut first, then remove flywheel? If I remove flywheel, if engine is on a stand, how do I remove crankshaft nut? Will impact get it?
Did you look in the glovebox for the wheel lock socket? I have missed your posts. Glad to see you back at it.
When you start on the crank nut dont forget to bend the nut keeper away from the nut. A 1 13/16 socket works also.
