And since we are talking about pistons here is the GEN2 piston. It does appear to have a little less dish but it's not a massive difference.
Very interested, just don't quite understand what you would like. Perhaps pm me as this post is starting to go off in another direction.@hazard hey man I just thought of something cool you could do. I actually bought everything to do it but I bought a bare head and would need to scrounge up some old valves, but since you like tinkering would you want to CC the combustion chamber??
I have a sneaking suspicion that more has changed on the GEN2 combustion chamber than we are thinking. To eliminate that much material they either had to flatten out the valve angle and decrease the max roof height of the combustion chamber or they had to radically change the piston. I do know the GEN2 piston takes much less boost than the GEN1 but again I have never had one in my hands.
The reason CC'ing the combustion chamber is important is if "we" do open things up, unshroud the valves etc, how much will that change the compression numbers? My goal when I bought my 10:1 Pistons was to plan to open the combustion chamber only enough to maybe drop to 9.75:1.
Like I said you really don't have to, I have the materials but if you want to give it a shot I could also do it and we could compare. Lol
They look like they actually might have more dish volume as they have dropped the squish pads. Know anyone who has these that we could measure. You can actually cc pretty accurately using a syringe or even a graduated measuring cup.And since we are talking about pistons here is the GEN2 piston. It does appear to have a little less dish but it's not a massive difference.
Sorry Scott. I understand now. I already cc'd the combustion chamber, piston dish and intake ports. I don't have the measurements with me but I recall chamber was 74, dish was 12 I think, can't remember ports.
I used a burrette and stand but didn't bother with the cover so may be up to 2 cc out. When I'm building I will be more accurate.
What was the reported stock compression ratio?
I agree, when I get back, I will get all my measurements and calculate exact compression of each cyl. I haven't made up my mind fully but as I am probably going NA I will likely design at 10:1, which would still withstand some boost if I choose to. Problem I have at moment is if I do go 110 the supplier (PPM Australia) will only supply complete rotating assembly, and I want to design my own pistons and rods as they are the crux to making this combo work. They say they have designed a workable package but the. numbers they give (stock except 110 stroke and 37CD, which is still 2mm too high)me don't add up. If they won't talk or deal I will go 107 with Crower and get my own piston and rods designedCool thanks!
Using the numbers you have so far surprisingly the compression ratio is only 8.69:1
Bore = 100mm
Stroke = 95mm
Headgasket bore = 103mm
Headgasket thickness = 1.34mm/0.053"
Combustion chamber = 74cc
Piston dish = 12cc
So coming up to 10-10.5:1 might give you some pretty surprising result.
About $10,000 Canadian dollars, crank, rods, pistons pins rings. $350 Canadian shipping. Cheaper than Crower, for the most part, and pretty sure it's a much higher quality product and probably a lot more experience in building these engines for big power as they service the sand drag guys from UAE. However, harder to get support probably if package is not up to snuff.Care to share what the entire rotating assembly out of Oz would be? Shipping?
I did a lot of work with the demo version of Performance Trends pro version. But that was before teardown and all the specs I generates. I may buy the program later but it's quite expensive. I really should buy it first as it makes working out dynamic compression ratio a snap over manual, and that really should be done before deciding on static ratio.They do have great software for lots of engine stuff, including a mileage performance program, engine building logbook etc.Have you built the engine in a compression ratio calculator program like Performance Trends has ? It'll give you static and dynamic compression ratios as well as cranking compression estimates(if cam specs & intake lobe centerline are input). It's been years since I've used my program and I'm wondering what the latest and greatest is. Had great results with an SBC years ago and the cranking compression #s were spot on.
Couldn't seem to find anyone on the internet that has used that stroker kit. I like the idea, but I don't want to be a pioneer... They go off and often have horrible endings.About $10,000 Canadian dollars, crank, rods, pistons pins rings. $350 Canadian shipping. Cheaper than Crower, for the most part, and pretty sure it's a much higher quality product and probably a lot more experience in building these engines for big power as they service the sand drag guys from UAE. However, harder to get support probably if package is not up to snuff.
Pure Performance Motorsport Home page
I don't mind being Guinevere pig. As long as planned well should really be no issues. Just a little concerned about working with someone at distance. I'll figure out what I am going to do soon.Couldn't seem to find anyone on the internet that has used that stroker kit. I like the idea, but I don't want to be a pioneer... They go off and often have horrible endings.
adI did a lot of work with the demo version of Performance Trends pro version. But that was before teardown and all the specs I generates. I may buy the program later but it's quite expensive. I really should buy it first as it makes working out dynamic compression ratio a snap over manual, and that really should be done before deciding on static ratio.They do have great software for lots of engine stuff, including a mileage performance program, engine building logbook etc.
If you bought the program and no longer use, do you want to sell it? What version?
