Builds 1997 FZJ75 Pickup (6 Viewers)
Well, I spent this past weekend tearing into the dash. Now I get to clean all this sand and dust out......
No, that's what started this rabbit hole! I replaced the compressor clutch bearing naively hoping that would take care of my problem. No go. So I just decided to go through the whole system. Now I just have to get it back together before I forget where everything goes 😜
While I have it out, I did a little refurb on the gauge cluster. I swapped out the bulbs for LED's, painted the needles and replaced the glass. My particular cluster has 15 bulbs.
Here is the paint I used for the needles and the bulbs I used from Super Bright LED's. The 194's are the large bulbs and the 74's are the smaller.
194-GCOB1W (Green) 4 req.
194-NWCOB1W (Nat. White) 3 Req.
74-GHP (Green) 1 Req.
74-NWHP (Nat. White) 7 Req.
That original glass ain't bad. Mine looked like someone sprayed oil on it in 2004 and never cleaned it. It was so bad.
Ha, that's actually a used replacement glass I put in to replace the original one that was much worse. I couldn't find a new glass at the time, so I settled for that one which isn't too bad. But I found a new one, so no more scratches (for now..;)
Since I have the dash out, it was pretty obvious it was time to replace what was left of the speakers..... :rolleyes:
I'm eventually going to get the door speaker pods, but in the meantime I installed these 4" JL Audio speakers. I swapped the brackets over from the old speakers to the new ones. I did have to use spacers to keep the speakers from rubbing against the dash, but it was a very simple swap.
Replaced the heater core and o-rings. I used 19mm (o.d) x 15mm (i.d.) x 2mm thick o-rings and added some Toyota FIPG for extra protection from leaks.
Heater core P/N: 87107-60220
Finished product of the heater core housing with foam replaced and heater core installed (and a ton of crap cleaned out!)
