Builds 1994 BUILD OUT and LS swap! Let's Go! (1 Viewer)
The new shafts I build are just under 4.25” Diameter. Toyota also uses a smaller diameter DC. It’s the joint with outside clips and found on some tacomas.
But those joints require pulling the shaft to grease and have smaller bearing caps and shorter needle bearings. The best I can tell is it’s about 3.75” in diameter.
Not much you can do, since the trans is mounted to marks adapter to center diff that relationship is pretty set. You could massage trans oil pan, not sure how much of a no/no it is to mount the driveshaft the other way?
I’m not sure either to be honest haha. Strength?
So this brings the question because im
About to set me trans and t case. I have Selkirk crossmember and a stock crossmember to work with. I will be mount the front shaft as well to check that clearance and make my decision haha
Tom Woods also has a smaller diameter DC option, you have to ask for it though. I just installed one on a truck and will try to remember to measure it today
And there very reasonable about working on there own stuff :cool: probably the most cost effective option
I’ll have to call. I thought the the smaller option was standard and the larger was an option. I’ll call tech support and see what I got and what my options may be.
Spoke to Toom Woods customer service. I did receive the smaller DC joint. They refer to it as the 1310. So it’s the smallest they offer and most likely the smallest typically used. I’ll clearance the pan a bit. The trans pan and drive shaft should pretty much move together at the center diff side. So I will try to get a bit more room if I can.
Not sure a cross member will affect the space from the center diff to fwd diff. I feel that’s more a relationship between trans and adapter. Might be some different angles that are created but not sure it would translate to more space. You’ll have to mess with it for sure. Take your time setting the engine and trans in.
keep us posted, im curious how this turns out, yea im going to be using a whole day to place it and get it right
