Well, swing and a miss.
Received the replacement bearing cap and it’s incorrect. Damn. Can’t believe so many different little variations with these engines.
You can see the differences between the two caps below. The ones I received fits around the crankshaft fine. But a number of differences:
Replacement on top, broken below:
The bolt hole on the replacement cap is too small. Mine has 16mm diameter bolt holes.
You can see the gap below against the casting on the block side: Incorrect one:
Correct one below:
Correct one to the right, incorrect to the left:
Ugh. Demoralizing.
Onur,
Would you consider having a replacement machined out of steel? The original is cast iron, so the mechanical properties of a replacement cap machined out of steel will be significantly higher. However if I recall correctly, the cast iron original might have different thermal expansion properties (rates of growth due to heating) than what might be realized with a steel replacement cap. If correct, try to select a steel alloy with a CTE (coefficient of thermal expansion) fairly close to cast iron to promote similar thermal expansion behavior between the cast block and a machined steel cap.
[so as the block heats up and expands, the replacement steel cap expands at a similar rate to the block => to avoid inducing thermal stresses between the cast block and the steel cap applying to one another]
Good luck with finding the correct replacement so you don't have to machine a part.
