crushers
post ho
i am thinking move the light switch to the other side and stick the bezel on the left...
Seats are comfortable and have a good support, perfect for a DD... have still a Recaro seat mounted in my 43
Take care of your 45, Kevin.
Have seen in one of your pics, that your foreman
can reach the door lock....
Cheers
Peter
Glad it got there - I can't wait to see it installed.
I love the wooden seat mounts - very ghetto. I say keep those to give the rig something of Budweiser Berigade look.
Josh
As this will be my first splitcase removal I am doing some reading and trying to decide if now is the time to rebuild the tranny and case as well or if I should just "throw" the toybox on there and do the rebuilds all at once later when I pull the axles off.
I was thinking since you are so handy, why not take dims of that tach bezel so you or someone else can start fabricating them?
I would definitely buy one!
If you mount the toybox you have to take the drivetrain apart anyway might as well rebuild it. Otherwise you have to take it apart a second time.
Great stuff so far, love your work.
2x on the tach bezel.
i would test the tranny before actually going to the expense of rebuilding it.
rebuild the t/case if you see signs of issues.
it is going to be quite the truck when you are done.
seems i might be delivering the troopy to Calgary in the spring and if i do i want to stop by and check out the shop and enjoy some fabricatting chats.
Hello Kevin,
As for your tranny - may be a bit late, but when you stand it on end, you should always do so with the shifter in place. Without the shifter, your Reverse selector is likely to pop out requiring you to pull the top loader to get it back on the track.
Josh
