I have the aluminum version with dual swingouts. Does anyone know what these are and where they go? I couldn't find any reference to them in other pictures or the instructions. Thanks
Thanks so much.Those are the recovery locations at the bottom of the bumper. See images below. Since you got the aluminum this is the method Ben and his crew came up with. I think its a solid solution for the recovery. Place a d ring and tell your friend to "PULL"
I would give Ben a ring and ask.Will they sell those separately? I don't think they were available when I got my aluminum bumper two ago. I've just used a warn tow hitch shackle for recovery
License plate brackets on the swing armI have a couple more left over pieces, any help would be appreciated. Aluminum bumper, tire swing out and Jerry can swing out.
Perfect, thank you.License plate brackets on the swing arm
Had this same problem, torque to a few grunts was the best I could do. Should be fine.Installing my aluminum rear bumper tomorrow. Any tips on bolting the swing arm nut plates to the bumper? I can't get any sockets on the bolt, they won't fit, not enough room, I can only get wrenches on it. Not sure how I would torque that to 100ft lbs with wrenches.
so is the entire bearing cylindrical housing between the upper and lower bearing seats to be filled w. grease (that be a lot of grease)?Once you put the swing arms on, start pumping the grease. Full sized cartridge and go with the parenthetical COA you were hoping to avoid. Your spindles will thank you for the lube.
You’ll need to grease them periodically. You should be greasing the drive shafts and U-joints every 5k anyways so just put a squeeze or two in the spindles while you’re at it.
Your truck is a half elegant machine and a half big, dumb animal that will go forever with a little bit of petroleum products applied in the right spots.
