Builds Zeke, the 1975 Wanderer and DD (1 Viewer)
Dumb question: Are the front vents supposed to be solid, or do they allegedly function as vents?
I appear to have vent pull hardware installed on both sides of the dash, which go to nowhere, and my front vents are solid metal.
If I buy the SOR front vents, how hard is it to fix it up to make them functional?
mine are the same..they pull air
I thought you'd enjoy seeing a picture of the pig when I bought it. It sat about 2 inches higher and had roller skate wheels. The cut-and-turn hadn't been done on the front axle yet, so the caster was way out of wack. The disc brakes were not installed. The thing felt like it was going to flop over every time I turned the steering wheel. Major body roll. It was not safe to drive. My main goal was to make it safe, then make it better. I didn't get very far. My to-do list was very similar to yours.:)
Ram air feeds those interior vents. It comes from the front through the chamber of the front fender cowlings.
That was a crazy looking piggy.
I really like it now, though.
I went out to a friend's house to play on his 160 acres of wooded 4x4 wonderland just now, and when I reached over to shift it to 4wd High, and not only did nothing happen, the transfer selector just wobbled there, without resistance.
Well, crap. I got underneath the vehicle, and noticed the transfer selector wasn't actually connected to anything. Poked around some more, and noticed something laying on the skid plate. Something that looked like this:
The cotter pin wasn't actually in it, but I found it by running my wand magnet over the skid plate. Couldn't find the nut and washer, but drove into town and purchased a new locking nut and washer, which I installed.
Now the transfer case works perfectly!
Happy days.
Well, today I got a full sized spare. Will pick it up and pay for it in a few minutes.
I also accomplished my first modification; I installed a step for that lovely short person in my life.
While I'm not thrilled at how far it hangs down, it is relatively easily removable, if needs must. Also note one of the fiberglass fender repairs has failed. Not a problem; I'll dink around with welding new metal in both of those when I get a chance.
I had to include a shot of the engine, resplendent in the glory of it's "2F" sticker:
After some experimentation, I've determined to correct amount of choke to apply for smooth running, and when to apply it. Anyone know more about how to service this air cleaner? I'm assuming it is cleaned, dried and then oiled.
Here is a shot of where the cross member was cut to make room for Mr. Saginaw
I bet I'm the only one with this coolio steering set up
It looks weird, but it appears to function quite well, so will leave it alone for the time being.
I ended up spending much of the day making homemade pizza for my wife's book club. That and driving Zeke around town on errands.
I used a carrier bearing in the middle of my steering column when I added power steering. Much tighter feel for the turns.
I'm literally going to trip and fall someday, because I look back to see it in the parking lot as I am walking away so often.
That problem won't go away, at least for a long time. It lastested over 25 years for me.
Well, I've done it.
I've quit the highly paid overseas contracting gig and returned to my home state of Iowa, there to live out my remaining time with my lovely bride and dog to be named later.
I got to actually see and drive the 1975 piggie named "Zeke" which I bought sight unseen from SuperT.
Based on his description and my inexperience with SOA lifted trucks, I was a bit anxious to get out and drive it.
After driving it for a couple days now, I can't say there is anything wrong with it. It drives (not surprisingly) like a truck. Stable and fun. Set up really well, imo. I love the color and the way its been set up so far.
The good: Oh, My Word, the interior is in amazing good shape.
The front bucket seats were very well executed. I simply love them.
This campy home made center console and drink holder is too freaking cool for words. When I saw the pics in the for sale ad, my first reaction was "ewwww". Now I think it is awesome. Plus it's the exact right height for shifting and resting elbow on while steering down the road.
As far as the exterior is concerned, I love the patina, the trail rash and the dents. Really has a "rough and ready" appearance.
The front disc brake setup is well executed and quite effective.
The best thing I can say about the Saginaw power steering conversion is that it works. It looks kind of hinky, and I will reinforce where the frame cross member was cut to make it fit.
The tires are brand new and quite aggressive. Will run these until they wear out and then consider possibly a smaller tire/lowering the lift a tad. Maybe go to a SUA 3" lift, as my wife and I get older and get tired of mountain climbing to get in.
But that is down the road.
I do have a laundry list of things to do to it before I have it where I want it in the short term.
A/C. No way will my better half accompany me to Pig Part 2018, if there isn't A/C in the mix.
Needs some kind of step/assist on the passenger side so my lovely bride can get in it easier. Am looking on input for this. She just needs a step of some kind.
Horn is inop and will need to sort that out.
New spare (ordered)
Heated seats to be added
Everything needs lubed. When I got it the hood was stuck shut. I squirted some Mouse Milk in that sucker and it released with an audible "pop", and now operates freely.
It is a touch cold blooded, and will stall at low rpms until thoroughly warmed. I'm wondering if the fact it's jetted for Denver Colorado might have something to do with that.
Will address most rust spots and then treat it with an oil based rust preventative before the salt comes out. This will be my DD for winter.
This rust spot is on both front fenders behind the wheels
Driver's side rocker is perfect. Passenger's side is rusting through and I will try to patch it prior to needing replaced.
Driver's side window handle was broken. I moved it to the passenger side rear seat, and will find a proper one to replace it.
Both the headliner and windshield are shot, but the PO helpfully included a brand new replacement for both. Will put them both in sometime soon.
My plans for this rig is to drive the wheels off it as both a DD and a Wanderlust machine. My wife and I will continue our expedition-ish driving we started in Europe and try to drive the roads less traveled throughout America. I'll try to update here as we go along.
That rust pocket on the front fender USED to have a wide support member behind it. It is held I place by the pinch bent at the trailing edge of the fender. I rebuilt the whole thing on my driver's side fender. I think I bought the last available OEM replacement fender for my passenger side back in the early 90's. They were already out of stock for the driver's side.
That problem won't go away, at least for a long time. It lasted over 25 years for me.
You DO realize this is all your fault.
I didn't even knew WTF an FJ55 was, until I met you.
BTW, that is my first planned sheet metal repair. I want to build a replacement patch that doesn't trap rust, though.
don't wait too long...Bob retired years ago and he's running out of stock! Maybe one day, a smart young man can help be his arms and eyes and re-re-create these pieces of art...till then; DON"T WAIT!
I'm learning how to metal shape as a retirement hobby/job. Zeke is just one of my "intro to" projects.
Nothing against Bob, just want to do this myself for the joy of learning/doing.
Just found this thread. Congrats on the nice looking piggy.
I'd be hesitant to drive it on salty winter roads though. :eek:
