Builds Wyoming 80 Build (2 Viewers)
I thought I had seen some freakin' nut-job anally clean fetish kinda dudes on Mud, but you just might have taken it to a new level! :eek:
Welcome aboard! (But certainly not new to wheeling and wrenching!) :cheers:
Thanks I guess... this clean is generally not my style but with a bead blaster it is so easy, so why not.
More cleaning and tear down
finally got the crank bolt off... had to buy a 3/4 impact, oh well I like tools
http://i582.photobucket.com/albums/ss270/yotakrawler/IMG_2244.jpg
http://i582.photobucket.com/albums/ss270/yotakrawler/IMG_2243.jpg
pulled out the oil squirters
http://i582.photobucket.com/albums/ss270/yotakrawler/IMG_2247.jpg
popped out the machine plugs
http://i582.photobucket.com/albums/ss270/yotakrawler/IMG_2248.jpg
pulled out this stupid bushing. I am getting ready to get the block tanked
http://i582.photobucket.com/albums/ss270/yotakrawler/IMG_2245.jpg
I used a sleeve from my ball joint service kit some washers and a long bolt... it worked great
http://i582.photobucket.com/albums/ss270/yotakrawler/IMG_2251.jpg
http://i582.photobucket.com/albums/ss270/yotakrawler/IMG_2252.jpg
I saw that one of the vendors on here was selling this bushing, you guys think I should replace it?
http://i582.photobucket.com/albums/ss270/yotakrawler/IMG_2254.jpg
If you have it torn down this far, then it probably isn't a bad idea to replace it.
I wish I had the skills (and the tools) to take it this far down.
I've had a few bushings that needed to be replaced. I clean the shaft on the oil pump gear with 400 grit emery soaked in Isopropyl alcohol to remove any bearing material that might have transferred to it. I then place the shaft into the bushing and check of play. If you can any play between the shaft and bushing I would replace the bushing.
The bushing needs to be pressed into the block for this as the ID will shrink slightly when pressed in.
So, I get the impression you may have done some work on cars before....?
I'm a good guesser! looking forward to seeing your progress.
Thanks guys, I decided to order a new one. I figure this far in I might as well
Thanks! But, I am not sure I always have the skills, I just usually go for it... I figure if someone else can take it apart and put it together, I can too.
Thanks! Yeah I used to be a Toyota tech. Didn't really like working on other peoples cars. So, with a little luck I should be finishing a degree in mechanical engineering in about a year.
nice garage setup!!! great progress!
Thanks!
Wow, impressive work indeed. It has been a while but I know I didn't have the time as a student to pull off all the work you are on this, well done! :cheers:
Looks like you've actually got a 209 York, not a 210.
You can identify the crank of the different models by the geometry at the end of the crank. Check out page 17 of the York manual and you'll see what I mean.
Not a big deal, unless you end up ordering parts.
Thanks I totally forgot that I had two yorks and only one was a 210.. here is my other one.
Thanks. Yeah I don't usually during school, just on Christmas break right now.
