Pavement test: WOW, I was not prepared for that! Before I could not imagine triggering the ABS on pavement, now with LSPV and ABS gone I can easily, at any speeds - Lock the hell out of the swampers (Q78, so around 35-36"). The gravel test showed they lock up at the same time, but need to test more as I just mashed the pedal. Thinking a gradual pressure on gravel. On pavement I mashed at about 50 MPH and damn near used both lanes to recover. I can't say if the back was coming around or anything like that, but I do not have any sway bars and my rig is set up very sponge-y. Just need to voice my opinion: If you are they type that really rely on ABS for the style of driving you do, I may not totally recommend this... If that makes any sense![]()
I had mine out on a gravel road yesterday and couldn't get them to slip at all, much less activate the ABS. Definitely going to have to look into this.My stopping is WAY better without. I have no ABS / LSPV and didn't add an adjustable unit. No matter how hard I got on the brakes I could ot even come close to locking them up, and never have had the ABS even activate. Without them the truck can stop much faster, in a shorter distance, stops dead straight, and braking is predictable and controllable (assuming a calm and controlled driver). If the brakes are so spongy and under powered you cant even activate ABS then deleting it is a no-brainer, I would say this would be the point at which you should do it.
Slam on the brakes as hard as you can: ABS activates = keep it, No pulsation from ABS = remove it. These units are old now and have air in them that can't be bled out
I removed both the LSPV and the ABS and was able to re-use existing lines for everything. The OEM lines are really high quality.Bumping a old thread. Referring to the original post, to connect port 2 to 3 will ether of the OEM lines flex enough to be used to connect 2-3 instead of buying a new 12" line?
For those of you that have done this mod are you still happy with it?
I just replaced another set of OEM front pads that only lasted 12,000 miles. My brake system, rotors, calipers, master, lines are new or rebuilt OEM. The truck brakes nice and straight, pads wear even. It just eats front pads. I have adjusted the LSVP arm up. Even made a bracket to raise the axle end up 2-3". I am thinking maybe the valve is stuck closed?
Good feedback, thanks for that. But, nobody can tell me that they rely on their f'ing ABS when you can't lock the wheels on dry pavement if your life dependent on it. Well, I never could anyway. Perhaps if someone relies on their ABS during the winter months, then they may not want to go this route. I'm part time so I gots no ABS anyway but that little light helps me to know when my hubs are not locked![]()
Open for now I suppose, but I want to test it on a dirt road and have somebody watch the rear wheels to see if they're locking up separately from the front, then adjust from.
p.s. I have that tee ready for you![]()
