CruiseOrlando
Conveniently Enhanced
I've added this index of things done to make it easier to find:
Integrated winch in bumper, 33's, front axle job
Front bumper & sliders installed
PCV valve oil/water separator installed
Battery tender installed
1" body lift installed
TJM 2.5" lift installed
Light mount tabs fabbed up, welded on bumper
Pintle hitch, iPhone mount, 12V accessory mount
My first GSMTR
Rebuilt alternator, installed 150A alternator
LED's in the dash
More LED stuff, front diff protection
Painted rims
IPOR rear bumper
Valve cover gasket, EGR/PAIR delete
5.29's
345's!
PT kit installed, Marlin low range gears
Slee 4" lift installed
Flares removed
Here's my list of things to do/done up here as well:
1) CDL Switch
2) Change horn
3) Install winch
4) Fix antenna (trail damage!)
5) New tires
6) Front axle job
7) New front rotors/brakes
8) Replace spark plugs & wires
9) Brake flush
10) Change diffs, transfer case & tranny fluids
11) Clean throttle body
12) Add oil separator to PCV valve
13) New front bumper
14) Sliders
15) Install iPhone mount
16) New lights on bumper
17) TJM 2.5" Lift Kit
18) Add +12V outlets, some switched
19) Replace PCV valve
20) New valve cover gasket (due to other work)
21) Replace spark plug grommets
22) Fix DS mirror wobble (again)
23) Fix turn signals (cuts off too soon during turn)
24) Fix small leak in transfer case
25) Change speakers, maybe head unit
26) Install 1" Body lift
27) PHH & Coolant flush
28) Blue fan clutch mod
29) 130/150A Alternator
30) Fix PS water leak (sunroof? A/C evaporator?)
31) On board air
32) Swing-out rear bumper
33) Belly armor
34) Hand throttle (I'm #132!)
35) Install 3* castor correction bushings
36) Fix broken rear swaybar mount
37) Install temperature monitor
38) Install CB radio
39) Install pintle hitch, remove standard hitch[/strike]
40) Upgrade battery/alternator wiring, prep for dual battery setup
40) Spraypaint rims
41) 345/75/16 KM2's
42) Part time kit
43) Marlin Crawler low transfer case gear
44) 5.29's
45) Slee 4" lift
46) Replace window runs
47) Extend brake lines
48) Extend diff breathers
49) Tube rear LCA's
50) Monstaliner the truck
Background:
I bought her back in October 2011. A 1994 with 170K on the clock, the PO didn't know what lockers were. He was the 2nd owner, the first was over on the west coast of Florida, who used it primarily to tow his boat around. She was in pretty good shape - load proportioning valve was bad and she had a leaky oil pump gasket, both of which were quickly fixed by a guy who really knows these Cruisers.
I took her out to a clay pit to play around a bit, took some flex shots:
It didn't take long for me to go back to the area and go places I aught not go alone. But hey, I was having fun... heading down a trail that had some big puddles... sticky puddles... and soon enough I got stuck. In the middle of nowhere. With no cell reception. And no one knowing where I was. Smart. Real smart.
This was the point at which I knew I needed a winch - more on that later.
One a trip down to Key West, I discovered the A/C wasn't all that great. It just felt like it wasn't keeping up. My father in law is pretty good with cars, and he knows a thing or two about A/C systems. After a bit of research, I decided a new expansion valve and dryer were in order.
Here's my thread on that process: A/C Drier - does short drier change R134 charge?
After changing out the drier and doing a complete flush of the evaporator, we didn't find any crud coming out, so we assumed the rest of the system was probably in good shape. So we sucked it down and refilled - it's been working great since.
This was also about the time I discovered I would need to do a front axel job, so that went on the list of things to do as well - the list was growing faster than I could get them off!
My first GSMTR
LED's in the dash
Painted rims
IPOR rear bumper
5.29's
345's!
Flares removed
2) Change horn
3) Install winch
5) New tires
6) Front axle job
9) Brake flush
14) Sliders
31) On board air
33) Belly armor
40) Spraypaint rims
41) 345/75/16 KM2's
42) Part time kit
44) 5.29's
45) Slee 4" lift
49) Tube rear LCA's
Background:
